30" light bar installed!
5280tunage
colorado
First, I want to thank everyone for adding their pieces to this, sure does help a lot and it's productive help!
I undertook this process today, was assuming it would be a two day project, first day take it apart, mount the light, the put it all back, then on day two wire everything. But it actually went a little faster than I thought, and unfortunately once you get some of this done, its kind of impossible to stop.
With that, I have included a few picture in case they help anyone else, and I'll give a few notes from my experience. I actually found the removal of the cover to be pretty easier, far easier than my previous vehicles (which also kind of scares me with this enormous $1K cover). The worst part was the wiring harness, I ended up popping it off of it's mount, so I could get to the tabs better. What a pain.
Once I got the cover off, mounting the light wasn't too bad. I relocated the temp sensor to about 1.5" below it's initial spot. This did mean that I had to tug on the wires/loom a bit but it worked out well. It's just about centered now between the bottom of the light and the cover. To mount mine, I ended up buying all stainless hardware from my local Ace, as the stuff that was included wouldn't really fit. I had to use the brackets inside out for things to line up. I also used nylon insert nuts to help ensure this thing wouldn't loosen as much over time.
That's when things got a little rough, for one, getting that massive twist on wire connector through anything in there was a pain, I finally loosened up the Left headlight mounts a bit, so I could squeeze it through a slot in the louver assembly, towards the top right (looking at it) there was a small section of foam insulation, managed to get it through there. But that took some work! I then mounted it under the headlight assembly to keep it from rattling.
Then I attached the wire assembly, and ran that across the engine bay, over the master cylinder, over the engine, to the battery area. That wasn't bad, found a perfect place to mount the relay. But then, I spent a good 1-1.5hrs trying to get the wires through the firewall. I started by trying to push an insulated 12GA piece of wire from the inside, through the grommet, but that wouldn't work, I then tried going from the engine compartment, through to the interior and that didn't work. Even after cutting off the cable ties, the bend they have these wires at, and the way the grommet sleeve was crimped down, meant I couldn't get anything to go through there. So I ended up carefully drilling a 1/4" hole through the rubber outer section of the grommet, and was finally able to get some wires through. I didn't use the Rough Country surface mount switch, to me it looked kind of janky for such a nice light, so I pre-ordered several LED push button style switches, and settled on the one in the photo, the blue goes well with the interior lighting I'm using. Oh, and I did use a switched circuity inside, so that my signal wire will only come on when the vehicle is on, just a personal preference.
One thing that worries me a little, is how hard it was to get the screw back in place below the ford emblem, unfortunately if I had it to do again, I would probably add some 1/4" or 1/2" spacers in the brackets to lower the light a tad, that would make it easier to get that screw in/out. To get it in, I had to kind of pry my socket extension between the light housing and the bumper cover, really made me nervous, but getting it out will be even harder.
All in all, probably spent about 5 hours of actual time. Not too bad, nothing like engine/suspension work, etc.
AKentPhoto
New Orleans
Well done!
I'm very jealous of y'all's bumper design. Got to love it when things work out like that. Looks factory! It is also nice to have when you need a little extra sauce on the flash to pass.
bushpilot
Houston, Tx
The Lightbar curve is almost exactly the same curvature as the bumper, so it really fits nice. I'll wire it tomorrow and mess around with aiming the light and then throw the bumper back on it. You could do it with the front wheels on, but its a pain to work around the tire getting the bumper cover bolts off.
Who's lighter is it? link?
sjwhiteley
Kentucky
does anyone have instructions on removal of the bumper / bumper skin?
In a nutshell:
Remove 4 small screws holding the fender liner to the inner fender (5-6mm diameter; use an appropriate std socket);
Remove a panel pin in each bottom corner of the fender liner;
Remove three screws holding the fender liner to the bottom of the bumper;
Do the above for both wheelwells;
Remove a 10mm bolt in the center of the fender grille;
Disconnect the sensor/fog light connector on the drivers side fender;
Remove three 10mm bolts in each fender well, just behind the lights (this is tricky to describe without a drawing: one facing towards the front and two pointing down);
Pull the fender off: it pulls down and forwards on each side (three short pins holding it aligned to the panel where the 10mm bolts were), and straight out from the front.
Diverdown
KC
That’s so cool. I keep thinking of doing this myself.
sjwhiteley
Kentucky
For those that want to add a light behind the bumper (which looks like a very clean install), here is a scan of the pages for a pusher bar installation discussing bumper removal. Once you know how to do it, it's not hard, just a bit fiddly (just like anything else).
(someone else had uploaded these, I believe, but couldn't find it again, so am repeating it in this thread).
5280tunage
colorado
The wire harness was a pain for me, granted, I didn't raise the vehicle and remove the wheels. I ended up prying it off of it's mount so I could better get at the connectors release tabs. I suppose I could have tried to get at it from under the front of the bumper as well, but then you get a face full of dirt.
Oh yeah, I didn't remove the wheels, but I had them full **** to the right, which gave me just enough room. I also found it nice to have magnetic sockets for a couple of these (the forward facing bolts).
All in all, this was one of the easiest bumper skins to remove in my lifetime (which also scares me lol).
On a side note, I really don't like the open cavities in this thing. I removed my lower air damn as I didn't like how it looked, but holy toledo, the number of open cavities front and back on this thing, and the mount of dirt, sand, and snow that piles up in these things. How stupid. I don't care if you give us plastic panels, I want these things to be more closed off... Anyone else notice this?
D
Deadman
Wisconsin
That big wire harness on the front left corner of the bumper was super simple to remove. Its literally a bail handle and it comes apart.
3tonsoffun
This is a Pavement Princess, it can stay on. I'm getting the FX4 skids tho to keep the snow out of the engine.
Pavement princess needs a 30” lightbar for what reason? To see the shopping carts at Walmart?
AKentPhoto
New Orleans
If there are half as many idiots camping in the left lane as there are here that is reason enough for me... Depending on where you are deer could be another big concern.
Fozzy
Riverton
Deer. I live In the middle of nowhere and run all backroads. The factory LED's are a joke.
Are you sure their aimed right? I have not driven any US vehicle with LED lights as good as the Expy or my F-150. I get flashed all the time. Even after having them lowered. Or are you use to Mercedes, BMW type vehicles. I have a 17’ Superduty with regular lights. They are almost as good as a dollar store flashlight.
D
Deadman
Wisconsin
I did aim them up and they improved, but at 45 mph on these backroads, they did nothing to light up the edges of the ditches and field edges, so it made me very nervous to cream a deer in my new rig. My Wife even asked me if there ws a light burned out, because she said it was like the lights weren't bright at all.
The light Bar I added is like 3X as bright as the hi beams when you turn it on. I can't even tell if I have the headlights on once the lightbar is on. I dim it for every car, or I'd literally get shot. lol.
5280tunage
colorado
For me, for some reason, even trying to pry the bail handle off didn't work. But now that I look at things, I should have tried from the front of the vehicle after removing the skirt, instead of through the wheel well.
D
Deadman
Wisconsin
For me, for some reason, even trying to Port the bail handle off didn't work. But now that I look at things, I should have tried from the front of the vehicle after removing the skirt, instead of through the wheel well.
Ya, I put mine on ramps and that was one of the easiest electrical connectors I've ever removed. Not much for delicate clips or anything to break.
