Advance trac
parkerdoug383
US
I have an 04 and the advance trac light on the dash is flashing what could be the cause and does it even matter.
MissileMech
Rocky Mountain High
That happened to me when my left front wheel bearing was floppy enough to cause bad readings from the abs sensor. I'm sure there are many other possibilities for the light.
the bus
Usually it is an abs sensor reading the wheel speed. But if that light is not on that is weird. You could unplug one of your front wheel sensors and see if the abs light works. When you plug it back it it resets quick.
