johnboneske
I'm still evaluating hitches, looks like there are 5 categories...
Cheap hitches that suck all around...
Amazing hitches meant for utility trailers only- geny
Good hitches that minimize but don't prevent sway- Equalizer, Blu Ox?
Good Hitches that claim to be 'Active sway prevention ' but may just minimize it better? Reese Straight Line
Expensive good hitches with proven sway prevention- Pro Pride, Hensley
Update- After further review, I think I'm going to go with the hybrid Reese Straight Line plus GenY Torsion setup that one of the reviewers here uses with a F250 and 12k lb trailer. I already own the 10k rated GenY hitch which I used on smaller trailers that didn't need WDH.
Etrailers page on the Straight Line hitch- https://www.etrailer.com/Weight-Distribution/Reese/RP66083.html
Might have to switch to the higher tongue weight bars.
We will try towing carefully with the non max expedition we have, and re-evaluate if braking power isnt sufficient , the trailer pushes around the expy too much, or keeping payload under limit becomes impossible.
We are limited to 1537lb payload on existing expedition, should be tight..but Ill try to keep trailer weight under 7K although that might limit how many batteries, propane tanks, solar panels, or other stuff we carry.
Trying to figure out what else I can do to avoid putting too much stress on the expy.
I assume Expy plus 32ft trailer too big to go to most gas stations? I fit the expy fine with 20ft trailer in the past.
What are you talking about? The Equalizer E4 has sway control. Dont understand
