Anyone try these on their Expy?
Scott Carden
Dallas Texas
23604844-0C52-42B7-B8A8-037B60B213E5.jpeg 8D590B80-5D72-4BF7-B533-26C65A08100B.jpeg 0FDD8F51-928B-4677-B727-F8B566A36468.jpeg I don’t care for the sumo springs as the can cause your springs to break on the ends. I am using bilstien 5100 adjusted all the way up and fords latest spring revision. Also a hellwig rear sway bar. The setup works fine towing or not. The downside to expy suspension being independent is that a helper spring or overload air setup won’t work. There are other options but get your wallet out as they are not cheap. 23604844-0C52-42B7-B8A8-037B60B213E5.jpeg8D590B80-5D72-4BF7-B533-26C65A08100B.jpeg0FDD8F51-928B-4677-B727-F8B566A36468.jpeg
Silver-Bullet-Bus
South Carolina
Sumo Coil—would highly recommend on all 4 corners, especially towing anything more than around 4,000#
...for the money & considering our limited options, especially, if you have a CCD Expy, these are a fantastic & relatively inexpensive option. They help to keep the back-end levels & greatly reduce front end porpoising on rough Ohio bridge joints.
2018 Max Plat
Savannah Dan
Savannah, GA
I don’t care for the sumo springs as the can cause your springs to break on the ends. I am using bilstien 5100 adjusted all the way up and fords latest spring revision. Also a hellwig rear sway bar. The setup works fine towing or not. The downside to expy suspension being independent is that a helper spring or overload air setup won’t work. There are other options but get your wallet out as they are not cheap. View attachment 41594
Do you have 5100s on all 4 corners? If so, are the fronts adjusted all the way up too?
Great looking ride. God bless Texas!
