Best penetrating oil
Tschroeder250
Tracy
WD-40 or PB Blaster or liquid Wrench?
Also, It seems like using a an oil like this will promote the nut/bolt loosening after they are put back together. E.G. If I use WD-40 to get a lug nut off, why won't the lug nut just slip off again when the tire is back on?
toms89
technical advisor
MD
Proper torque !?
Fasteners that have sufficient vibration and can work themselves loose over time generally specify some sort of thread locker. Typically smaller ones where you cannot get sufficient torque without breaking.
I have greased all my lug nuts long ago...
toms89
technical advisor
MD
I hear PB blaster recommended far more often than the others for removing seized fasteners.
01yellerCobra
San Diego
My grandfather recently told me of a hine brew that is a 50/50 mix of acetone and ATF. I haven't used it myself. But him and his friend swear it works great.
Misspelling brought to you by Tapatalk
01yellerCobra
San Diego
Owned by the double post.
Idahokid
Coeur D Alene
I work for a truck dealership and we sell PB blaster all day.I had a customer last week ask for some Howes penetrating oil.Says its the best.Wd40 stands for water displacement.And its the 40th formula.Just some trivia.
kythri
Lebanon, OR
Kroil rules.
Google Deal <--- Intro deal for a couple of cans of Aero-Kroil (aerosol cans, you can also buy the stuff in liquid form for your own dispenser).
GREAT great stuff.
JUST4FUN
Admin
Moderator Administrator
Il
Look up tri-flow I really like this stuff
Lightnig
Behind you
I am a big fan of the blue tipped wrench. never any problems removing a stuborn nut with that...:laughing1:
Other than that, pretty much what ever I have on hand. although good ol' 3 in 1 still does great job without the crappy residue the WD4* seems to gather if left alone...
whowey
Illinois
There are literally dozens of penetrating oils out there. Almost all of them are pretty good, because they are based on the same materials. WD-40 is not a penetrating oil though. It is a pretty good water displacer though. It will really take the moisture out of places its shouldn't be.
Yudaman
Southern Oregon
CRC Knockerloose. Far better penetrant than Kroil.
As someone already mentioned, there is not a bolt or nut the a Victor wrench can't remove.
Piratelife
Nc
I really like PB blaster. I'll second the blue tip wrench as well. Basically I like whatever works when something is stuck, squeezing, or not moving smoothly. It also depends on the application.
shutchins
ontario, ca
Penetrating Oil
PB Blaster is my weapon of choice, especially if you're doing the dreaded spark plug swap on the 3V 5.4
B
bedrck46
yield was the best I ever used but they are all good if it gets the job done just some do it better than others
vince0190
manila
WD-40 Great product, just used it to remove sticky residue from my car due to a sticker I just peeled off.
