Bilstein + Sumosprings ride height?
J
Joey Smith
Sunnyvale, CA
This one is upside down. It will raise your ride height by inches if upside down. The opposite side and front looked correct to me. I would also suggest on all 4 counting the number of visible snap ring grooves.
If I remember correctly this is the passenger rear strut. If only that one is upside down and higher, seems like that explains why this is the one that appears to be 2-3 inches higher and why there is a lean (passenger higher than driver side). The height increase is less on the passenger front but is still higher by about 3/4”. Would just messing up the passenger rear explain all I am seeing?
Thanks very much to all for spending the time to read and respond! This forum and community have been great. Much appreciated.
sjwelds
Kansas
Yes, would definitely cause this if one is upside down
sjwhiteley
Kentucky
For the lean, I'm not familiar with the install, but of the A arms are torqued to the frame with weight off the wheels then it could cause the bushings to twist and cause a lean at rest. It will also cause premature bushing wear.
Glad you got it fixed and Not to derail the conversation Where did you find rear bilsten 5100s. I have been waiting on a order for 4 months for my rears (replaced the front but rears are back ordered)
J
Joey Smith
Sunnyvale, CA
I purchased them from Oreilly’s Auto Care in 2020 (had to have them order it but it showed up pretty quickly at that time) immediately before the Covid shutdown…
sharprd65
