It’s odd both those cylinders can’t manage any pressure. That’s usually a catastrophic failure (valve and piston meet) or a stuck open valve. They are on two different banks.
Looks like someone is going to tear down an engine....
Anytime your compression doesn't budge after squirting oil in that cylinder, it's usually valve related. Bad rings or something bottom end will jump up. That's good news I guess. The low compression on 5,6,7 bug me though. A motor with that low of mileage, should be 140 or higher. Anyhoo, that drivers side valve cover needs to come off. Now you see why old school compression tests are still the best. A scanner couldn't pick up a wet test. I don't think they can. I think the gang here can walk you through the top end teardown/rebuild I'd get a Ford repair CD, I have a copy of one that I got a couple of years back from our departed friend Bob aka Bedrck 47. I'm not using it right now. Mines a 2000 year , Pm me if interested. I can throw it in the mail. You can mail it back if you don't want to keep it.
Did you see the needle jump and suck back down quickly when you were cranking it?
Need to pull valve cover. It is not likely at not the most likely thing that you have a valve seat or other thing preventing sealing.
More likely that you have a follower off and intake is not opening so you get no air in to compress..or a valve is stuck open or bent(worse).
You need to inspect them and crank it with valve cover off (pull fuel pump fuse or relay) and watch to see if they go up an down.
My guess is you will find a "rocker" follower laying in the head jammed sideways and holding valve and spring down.
Here is an old mechanics diagnostic trick. There is a fitting that allows you to put compressed air into the cylinder so you will need that and a source of compressed air. Shoot high pressure air into the cylinder and have a listen:
Bring the #8 cyl to tdc on the compression stroke. You can tell that by the direction the cam lobes are pointing for that cylinder. Both will be pointing away from the engine.
If you hear air leaking in the intake it is an intake valve, air out of the exhaust pipe - exhaust valve, air out of the oil fill cap - 1/2 keg of beer because you are tearing into the engine or replacing it.
Should you decide to tear into the engine...I'm going to assume it will be your first one. Is that correct? If so you will need a few tools that most diy'ers don't usually have.
1) Quality torque wrench (200-250ft/lbs) and maybe torque angle gauge
2) 1/2 drive socket set
3) good sized combo wrenches
4) air impacts would be really nice
Just to name a few....
Does yours have the dual overhead cams? If so add #5 to the above - a kegenator
I realized after my last post that yours is the 32 valve Lincoln motor. My CD won't help with the cam timing, but I'm sure you can get that part online and print it. Your 04 CD should work for a lot of the specs and other stuff. Just remember to bag and label the small parts. Use Ford parts if still available. If it does turn out to be a broken spring or valve, you most likely will have to pull intake and that head. We had a guy a few months back trying to do his 2 valve Expedition on the car, but couldn't get any tool in there. Do you have a machine shop that can redo your heads? We're all curious what happened.
The needle jumped up every time the engine cranked over until it appeared to reach a max number (except for #8 which did not move the needle at all). I cranked it over maybe 8-10 times for each cylinder.
Then it should have either been smoking very badly out the tailpipe for making lots of popping or noises when it was running.
If one has zero compression and it doesn't jump up and down then it either has a hole burn in the piston or one of the valves is completely open. I guess if the exhaust valve was the one that's open it would run decently and not pop where you can hear it. It would be popping out the exhaust and the muffler so it wouldn't be that noisy.
