1955moose
- Joined
- Nov 23, 2014
- Posts
- 5,981
- Reaction score
- 1,338
Do a compression test of that cylinder, actually I would do all banks to be sure their all balanced within each other and pull valve cover and inspect it visually. I know the new technology can show basic engine balance, and compression through scanners, but nothing like doing a full eight cylinders compression test with a quality screw in gauge like Snap on, or Matco. A cylinder balance test with a pressurized gauge is standard procedure with any compression issue. Tells you if you've got bad valve, valve guide seals or rings. A weak valve spring is a little tougher to diagnose. Unless it's visable, like laying in the valve cover, a weak valve spring would usually require pulling that cylinder head, dismantling that suspect spring, and tensile test it. Not a common issue, but anythings possible.
