I decided to change my new 2019 XLT at 1500 miles and I'm glad that I did. The factory oil filter did a great job to filter metal particles and I saw some particles in the oil as well. My 2019 has metal oil drain plug instead of plastic and it wasn't that tight when I removed it. Oil change is simpler than my old Acura MDX, dropping the plastic cover by removing 4 8mm bolts. I was surprised that I didn't have to use much muscle to break it, same thing with oil filter, it wasn't tight either. I also installed a new Fumoto 107N for easy access later. I used Penzoil Platinum 5w30 synthetic with Mobil 1 212A extended oil filter. I could tell that the engine is running quiet than factory oil and my gas mileage jumps from 15 mpg to 17 mpg.
If you guys have a new Expedition, I recommend to change out new factory oil with synthetic after break in period or after 1000 miles. I'm planning to change oil every 5k miles.
