Front-end squeeks
Fastcat
St. louis, mo
I took my car to get it inspected and when the guy took it off the lift and drove it out it sounded like worn out bed springs everytime he turned the wheel in either direction. It wasnt doing this before the lift...n What could it be?
Lane24
technical advisor
Alberta , Canada
Are your truck's front ball joints greasable? If the are aftermarket, they might be. Mine gets pretty squeaky when they need greasing. Even swinging open the door and stepping on the running board will make it squeak. Sounds like an old wagon driving down the road. Hopefully that's what it might be.
walnuts4x4
Watertown, NY
+1 on ball joints... hopefully the need to be greased or if a lot of dirt has built up it can cause that... or last resort... the ball joints are shot and need replacing... I just went through this problem last summer
Expeditionary
Tampa, Florida
My front end has a slight squeak to it when turning the wheels, but only when it is sitting still. If i get my guy to grease the ball joints should that fix it, I would hate to have to get them replaced $$$$
Zombie
Oklahoma
I just purchased my Expedition 2 days ago and it drove perfectly with no squeeking. Yesterday I accidentally hit a pothole big enough to get lost in and now my front end is squeeking to. Guess I better get my grease gun out.
F
Fastcat
St. louis, mo
I greased the ball joints and its still squeeking. It squeeks when turn and hitting bumps... Anytime the suspension moves... Its annoying but more embarrising lol
walnuts4x4
Watertown, NY
I'll put my money on "you'll need new ball joints" probably both upper and lower.... because what you are describing happened to mine last summer... exact same problem
F
Fastcat
St. louis, mo
Its been raining here the past 3 os 4 days and the squeeking has stopped... And I've greased everything on the suspension besides the rack and pinion. U still think its my ball joints?
ExpySport
Media, PA
How do your swaybar bushings look? I had a bad squeak in my frontend and it ended up being the bushings. Replaced them and noise gone. Worth a shot and a lot less $$$$ than ball joints.
99 Expy
Laramie, WY
I replaced my squeaky ball joints last summer. I think it cost me right around 200 also, but I bought the entire upper front control arm since Moog doesn't make ball joints that fit the stock upper control arm. Its not super hard to do, but just have to be careful to make sure everything is put back together properly. I rented a ball joint press from O'Reillys.
