Headlight bulbs low beams.
RenegadeBad_Dog
South Carolina
I know this topic has been beat to death by now but I am looking for opinions from people that have replaced there bulbs. I do a pretty decent amount of night driving and I need to get brighter bulbs. It's for a 2016 Ford expedition xlt I believe stock halogen. I'm looking for preferably white LEDs to match the fogs but I am open to any option. I am just looking for people who gone to less and what the best option would be for the cost/quality.
Sent from my SM-G973U using Tapatalk
16plati
VA
Diode Dynamics SL1 LEDs
Too many ppl have had issues with HIDs burning out. Thts why I chose LED, 100% plug and play and perfect fitment behind dust cap. They were R&D’d using the projector lens and to have same fitment as OEM. I now have both highs and lows and it’s exact match to OEM fogs
Grover6
Calgary
What 16plati said...I went to an aftermarket HID kit, which was great while it worked. I was getting about a year out of the halogen bulbs, and ended up to be about the same with the HID. The ignitor on one side also burnt out, which adds to the cost. So I have gone back to halogens pending an LED upgrade. LEDs are a big price jump from stock, but should last a long time, and they are cheaper than the HID kit I had.
LRNAD90
Maryland
Do any bulb updates really make a difference in the performance of the headlamps, or just a brighter hot spot in front of the truck? It seemed to me like the XLT reflector headlamps are just poorly designed from the standpoint of focusing and delivering the light down the road. I've heard the Limited's projectors aren't much better, but no personal experience with them. Maybe worth fitting the Projector (Edit - not Reflector as originally stated) headlamp housings from a limited to the XLT to better control the light, and have it be effective at illuminating the road further out, with c sharp cuts offs to prevent blinding oncoming traffic (And yourself from reflective street signs)?
Langer
Chicago
I have these in my 2017 XLT. They are a significant upgrade. I felt like it was sincerely unsafe to drive with how dim and yellow the stock ones were. Easy install, no problems thus far. Got them I. January 2019.
NINEO H11 H8 H9 LED Headlight... https://www.amazon.com/dp/B01MDOWGY3?ref=ppx_pop_mob_ap_share
16plati
VA
Do any bulb updates really make a difference in the performance of the headlamps, or just a brighter hot spot in front of the truck? It seemed to me like the XLT reflector headlamps are just poorly designed from the standpoint of focusing and delivering the light down the road. I've heard the Limited's projectors aren't much better, but no personal experience with them. Maybe worth fitting the reflector headlamp housings from a limited to the XLT to better control the light, and have it be effective at illuminating the road further out, with c sharp cuts offs to prevent blinding oncoming traffic (And yourself from reflective street signs)?
I get better quality and more light out further in front of me with the SL1s
Grover6
Calgary
If you have the reflector style headlight, a bulb upgrade will help, but not as much as if you have the projector style. From what I have seen, LED bulbs don't work as well in the reflector housing. They look really bright from head on, but the reflector doesn't push the light out as well and so you won't get the reach down the road. Think mildly focused flood light (reflector) vs focused light (projector). Might be worth checking into the projector housing prices, or a wrecker.
lbv150
Northeast
I run the OEM bulbs in my '16 Expy and they are plenty bright enough. Impressive in fact. Jeez you want to be one of those inconsiderate drivers with blinding low beams? I do a lot of driving and those people are the worst to encounter on the road at night.
chuck s
Maybe your '16 has decent low beams. Those on my '17 were strikingly dimmer -- put less light on the road -- than either my wife's Subaru and even my '06 Honda S2000. These HIDs were professionally mounted and aimed. Been driving this setup for 8 months and yet to have anyone flash their high beams telling me to dim mine (low beams).
Light color (temperature) makes a big difference in glare. Ricer White (tm) is particularly obnoxious.
-- Chuck
LRNAD90
Maryland
I guess like so many things, people's impressions vary, but I found the '17 Expedition I drove to have Horrible headlights..
MuddySpokes
There & Here
Low beam projection is good on mine with the OE H11. Have experience and confidence with towing at night too.
If I do switch to LED's, it will come from a goal of lowering power consumption to reduce the alternator's load.
Reason I am holding back on a LED conversion is that (last I looked) there is no DOT compliant replacement for a H11. Definitely do not want to swap bulb technology and be that glaring guy either. To some this is important, to some not.
Just checked out Diode Dynamics. While there is a claim of "Street Legal Output", this is not the same as DOT compliant. Just say-in. The SL1's are a little too far up in the kelvin chart for my taste too, but that is just me.
16plati
VA
If you adjust them correctly they won’t be an issue. Don’t knock em till you try em
old codger
Jefferson City
I have a question on installing led's. Even the diode dynamics have an adjustment collar to adjust the beam. Is there an easy way to adjust the led bulbs without having to remove and install housing numerous times as this can be a pain in the arse. Thanks
16plati
VA
There is a hole in the top of the housing where if you look down in it you will see a small white gear. Moving this gear left or right will move the bulb up or down. You can access this without removing housing
