Help! Passenger Low Beam Headlights Out!
DKDNU
Houston,Tx
I have a 2003 Eddie Bauer Ford Expedition and the low beam for the passenger side doesn't work. All the other headlamps operate fine. I have changed the light and the socket with no luck. Has anyone else experienced this and if so, what's the solution?
Hamfisted
Ft Lauderdale
On the Gen2 Expy fuse 23 is the right front headlight. Check that it's good. Then check for voltage at the headlight plug itself. If you need it, the wiring diagram is on page 4530 of the shop manual .
D
DKDNU
Houston,Tx
Don Hall & Hamfisted you guys were correct. I thought because the other lights were working that it couldn't have been the fuse but it was. Fuse spot #23 was blown and the low beam works fine. Thank you guys.
