Re-powering; the nickel tour
Thanks Burch-- I'll try that. I always want to try the easy stuff first.
Here is the short version of my re-power. First, take out the thirsty 5.4L gasoline eater:
Then remove the stock motor mounts with the hot wrench. The 4BT is much wider at the bottom than the V8, so the mounts need to move outboard. The passenger side mount is also moved ahead a little. I re-used the liquid filled isolators from the V8, so they fit back into their original pockets.
Then re-weld them back on the frame rails, with appropriate reinforcing. The auto transmission is gone too:
Then set the 4BT in its new home. This engine is just a little longer than the V8, so this method of setting it down in the engine bay sideways worked best. Once the flywheel housing is down below the cowling it can be turned straight.
After a few weeks of making all the connecting runs for coolant, fuel, air, intercooler ins and outs, wiring, sensors and controls-- you are ready to drive it again. There were of course a few pauses to figure out what to do next and "oh man I didn't see that one ahead of time" kind of stuff that happens when you do something like this for the first time.
I will post more in the members' section later. Thanks for all the greetings and encouragements!
CR
