Initial Surging/Jerking on Cold Startup 2001 4.6 Expy
Ulver
Tennessee
So, it's been about a half year since I've had this vehicle, and much work and improvement has been made to my 01 Expy. The fuel trims are decent; around +5 to +7% LTFT on both banks. No codes.
However, there's this one issue that I still have.. My vehicle jerks on acceleration (from 0 mph) while the engine is cold. This happens only on take off. I'll press on the gas, and the RPM's will go up, but nothing will happen for a couple seconds, then suddenly I get this "jerk" forward. So the only time this happens is when the engine is cold, and when I first take off. This issue doesn't appear in any other instance. This doesn't happen at all once the engine is warmed up. What could this be?
1955moose
Torque converter. The other possibilities are a bad front pump in your transmission. Any codes at all?. Do you have a trans shop or repair shop that's fair, and good with diagnosis? A friend of mine has a pumped up 67 El Camino, and had a similar situation, his turned out to be what is called a sprag gear go bad in his automatic. Let us know what they find.
Ulver
Ulver
Tennessee
No codes. I do have a reliable repair shop I could try.
I'll try running the Expy tomorrow with the manual mode and see if this still happens. If I remember correctly, if the problem happens in manual mode, it's most likely not a transmission problem, but if the problem does not happen in manual mode, it most likely is the transmission? Thanks for the feedback.
Ulver
Ulver
Tennessee
Okay, here's a follow-up. I changed my transmission fluid this weekend. And I mean all of it, including the fluid from the torque converter. I haven't had a problem ever since. So if anyone else has experienced this issue, be sure to drain all the fluid. Not just the fluid from the drain pan.
M Bennett
