Let's See Those Lifted / Big Tire Gen 4s!!
jkocr2
illinois
305/70-17 +12 offset minor trimming on the lower valance and had to push the fender liners forward about .5”
Nav_Feste
Denton TX
Finally got rid of the 22's and put on these Fuel Rebel 17x9 on 285/70/17's got lucky and no rub and no flex issues (at the mall so far) but will be putting on a level kit next, wish they had a 2/1 kit out there, don't really feel a 3/2 is necessary for this setup so far. LMK what yall think, thanks.
AMG04
Fort Worth, TX
Finally swapped the factory 22s (285/45r22) for 18s from KMC with 35mm offset. I've always had good luck with Nitto Ridge Grapplers, so that's what I wrapped them in.
New tires are 275/70r18 (33") and fit great with no rubbing.
Chrome delete is up next for the weekend project.
LazSlate
Arizona
leirej
SoCal
Looks great. I almost went that tire and rim but went 17 with 305s. Toyo Open Country. Toyo Tires are great and pretty quiet.
By any chance did you fix the speedometer? I'm about 3 mph off. Tried to run forscan but it says it doesn't recognize my vehicle. I guess there no support for the 23 Timberlines yet.
LazSlate
Arizona
No support yet. I do not mind the spedo off as long as you remind yourself it reads slower than you are actually going.
In the long run you will have a lower odometer reading for same miles driven as if you had stock tires.
