New camper - Sag issue
TX_Trails
Anna, TX
Hello everyone. New to the site but I am loving it! I just got back from taking my family camping in our 2017 Expy EL Limited. I'm towing about a 6,000 pound trailer and having zero problems with that part so far - haven't really had to deal with any hills yet. My issue is the sag I'm experiencing. The hitch weight on camper is 625 pounds and the tongue weight on the expy is 650. I know I'm cutting it close there but I'm pretty far under on my tow weight. I've been looking at solution like sumo springs and air bags but though I'd ask here to see if anyone else has had this problem and what they've done about it. I am not digging the rear squat at all! BTW, I am using a WDH Husky Centerline. Thanks!!
Tim Fuller
Upstate NY
Have an rv shop set up that WDH. Load bars should be near parallel to ground from what I've been told. Also, is there a lot of gear inside Expy? Anything behind rear axle is considered "tongue weight"
B-McD
Illinois
TX - Nice camper you have there. I tow a similar one - 30' APEX and about 6500lbs loaded. I use an Equalizer WDH and have a regular wheelbase Expy. I only drop about an inch when fully loaded. I would double check the setup on your WDH and make sure you are following the mfgr's hook-up procedures. It doesn't look like the WDH is transferring any weight to the front of the truck. I am assuming you are not putting a ton of stuff in the back of the Expy, right?
Nice dry campsite you got there!! ;)
T
TX_Trails
Anna, TX
Hi there! Thanks so much for the response. I purchased the trailer used (I think they took it out on two short trips) and it came with the WDH. I didn't make any mods other than plugging it into my truck. There's nothing much that we've put into the trailer - especially near the front. All I could think of would be a few blankets. I did have some gear in the back and I guess that could have accounted for some of it so maybe I'll watch that next time and see if it changes anything. Thanks for the tip to get it redone at an RV shop if you think it will help! Also, yeah - first setup was in the rain but the next two days were beautiful which is what I was counting on.
powerboatr
North East Texas
you need to set the wdh up correctly, that nose high setting is dangerous as it takes control weight off the the steer tires.
Ideally you should be level.
search you tube, thousands of viideo to show correct set ups.
chuck s
I'm betting your trailer weighs well over what you think. What's the GVWR of the trailer? -- should be on the outside data plate. The UWV (unloaded weight) is mythical. Ignore it, it didn't exist once the trailer left the factory. Salesmen will lie and tell you this is what the trailer weighs and that your Expedition can pull it.
Just looking at the photo my guess is the trailer is closer to 7000 or 8000 pounds than 6000. Where is the 6000 pound number coming from? Where does the 625 pound tougue weight come from? Did you measure these?
6000 pound camper needs 10% to 15% of total weight on the ball and my trailers tow better toward the 15% range. That's a range between 600 and 900 pounds IF your trailer weighs 6000 pounds which I'm betting it doesn't.
BTW the maximum towing capacity of your Expedition is computed with the truck completely empty other than a 150 pound driver. Every pound you weigh over 150 and the weight of all cargo cuts that capacity.
-- Chuck
jimz
florida
While adjusting the hitch so the camper is level is good the front of the hitch must also be adjusted to allow the TV to ride level. That is the whole purpose of the hitch. When either side rides off level it can be corrected in the hitch adjustment.
T
TX_Trails
Anna, TX
Chuck, the camper is a 2018 Keystone Passport 2920bh. Dry weight is 5,385 pounds and we haven't put much in it honestly as it was our first trip Also, I had winterized it a couple months back so there should not have been any liquid in the trailer anywhere. There were some camping chairs, fishing poles, and a bag with hammocks in the back of the expedition. I was the only person in the vehicle but wasn't in the vehicle when I took the photo. The hitch weight per the trailer specs is 625 pounds. I was estimating 6000 pounds but could bump that to 6500 I guess Regardless, I don't think I'm overdoing what the truck can handle and just want to get the squat resolved. I'm going to take it to an RV place and let them redo the hitch setup professionally. I have not modified it from the previous owner.
chuck s
I'd personally assume the trailer weighs 7200 pounds, the GVWR. You can easily add well over 500 pounds to the trailer and it'll still not have your stuff in it. Water, LP, dual batteries, will do that in a heartbeat. Remaining below the GVWR is very often a challenge, especially with a family, hence I'd set up for max weight.
Trim lines above the XLT have HD tow standard. Otherwise it's an option. With HD Tow it's no sweat. The engine has plenty of pull.
RV places are the worst place to adjust a WDH in my limited experience. Put aside a Saturday morning on a level site and go thru it step by step as loaded. Fill the fresh water tank, add appropriate weights to at least simulate full propane tanks and two batteries. Waste tanks are your call. If they're behind the axle towing with much of anything in them can unload the tongue Basically hand tools for my Equalizer (tm) WDH. I know the tongue weight has pushed 800 pounds a couple of times. I have a tongue weight scale I use when loading UHauls, etc. Plenty of videos on how to make a tongue scale using your bathroom scale a board a couple of blocks and a refresher on how levers work.
-- Chuck
Tim Fuller
Upstate NY
I could be wrong, but I believe the data card on the side of camper accounts for propane and batteries. Obviously pending any mods by previous owner (bigger tanks, more batteries etc.)
Also, if possible, don't travel with a full fresh water tank. It's unnecessary weight. Fill up when you get to campground if there is no fresh water on your assigned site
powerboatr
North East Texas
only way to KNOW 100% what the trailer weighs is to go weigh it
I use our local feed store..they dont charge unless you need a print.
i have used them many times to weigh the bus and associated crap we take along.
go set the trailer on the scale not hooked to the expy.
get this as your total weight
then move it so the tongue in on the ground and the wheels are on the scale
then take that weight and subtract from the first weight. that will give you the axles weights .
then back up and have only the hitch jack on the scale and the wheels off the scale, this will give you the tongue weight.
then you know real world what the hitch weight is and can set your wdh accordingly.
ASLO while at scales, get a total weight of the expy with all four wheels on scale.
then a weight with just the rear wheels on scale, this will give you front axle weight and rear axle weight
then set up trailer to be level when correctly hitch to the expy.
finally go back to scale and place front wheels on scale. get the weight
then pull just expy on scale to get new weight of expy hooked up.
then pull entire rig on scale. get this weight and finally pull forward to just have trailer wheels on scale. to get now the hitched up axle weight
if everything is correct, your front axle weight will be higher, your rear might be same or just a bit higher and the trailer axles should also be higher, as the wdh transfers weight to the front axle and the trailer axles if set correctly and still keeps rear axle within rawr
if you can....after all these weights...unhook the wdh bars and let the expy sag. then go back and weigh the front axle and the rear axle. this will tell you right away how much weight is being transferred
i know this is time consuming, but its really the only way to know exactly real world weights.
then you can load both safely knowing how much weight is at each point .
your trailer axle weights will gain a few hundred pounds if the hitch is set correctly.
this is not an end all solution, only brief to what reese and husky have in their documentation
T
TX_Trails
Anna, TX
I have the HD tow which is part of the reason I went with the limited. 1 battery. It would be a rare day that I hauled fresh water. I'd rather not guinea pig myself with the hitch setup since I've never messed with it before It would be nice to have someone who knows what they are doing.
Frank R
NE PA
That's a great TT. I have the exact same model, only it's a 2019. We picked it up late last year. I am using a Reese Strait-Line dual cam WDH. Towed it twice with my old Tahoe and it towed beautifully. The new axle setup on those makes it track much better on the highway, but does take some getting used to when backing it into tight spaces - it does not cut quite as sharply as other similarly-sized TTs I have owned.
I look forward to seeing how it does behind the new (to me) Expedition. While in a U-Pull-It junkyard looking for a console solution (I have a SSV), I found a brand new Tekonsha Prodigy brake controller with wiring harness (SCORE!!!), so I'm psyched to get rid of the junk one I had been using. If only Spring would arrive here in NEPA.
Best of luck with your new rig - I hope you enjoy it as much as we do ours.
Fasttimes
Miami
TX, I've been going through the same issues with my set up as well. It's definitely a pain in the rear no pun intended. My set up is pretty similar, similar sized camper, same sag. I have the equalizer hitch and it's similar to the Husky in style and I'm pulling with a 2010 Expy with HD-tow package.
First I tried setting up on my own, then I paid Lazy Dayz dealership in Tampa to do it and it still wasn't great. With 120k miles on the truck I thought it might be time to swap the struts/shocks thinking that might be a major contributor, but I did that and it still has sag. You have to play with the various areas you can adjust. In my case there is the hitch height, some washers that adjust the ball hitch angle, and finally the WDH arm height on the trailer. After putting in the new shocks and struts the truck sat much higher, so I had to re-adjust the ball height. Now I'm at the point of adjusting the arm settings. Moving the arm settings up will transfer considerably more weight on to the truck front axle. Just make sure that you measure the gap in the front wheel well before hooking up trailer and after hooking up with WDH engaged and that there is no instance where too much weight is being transferred onto that front axle and the gap in the wheel well has gotten small. .
I still have more adjusting to do to get it right. My guess for you is to raise those WDH arm settings higher and you should see weight transferred onto that front and less sag. It definitely is something where you need to spend a whole day with some help making adjustments and hitting the highway to see how they respond.
I truly wish I could find a proper after market suspension leveling kit. Haven't found one yet to fit my 2010.
JerEazy
Sarasota, FL
Yah - you just need to set up that hitch correctly.
Husky TS is a good hitch - my Father In-Law has one. I’ve debating getting on.
Check some YouTube videos and you’ll be good to go man.
You’ll get some sway regardless based on the length of the trailer. That 29 is probably 32 or more tip to tip. The placard that says tongue weight doesn’t include anything (batteries, propane etc).
The set-up is not a set it and forget it. I’ve got the E2 hitch and I’ve been adding and removing washers and adjusting brackets etc.
Send me a message if you want a step-by-step. And don’t be afraid to reach out to the support teams at Husky. They’re great
jimz
florida
https://diskdoctor.us/camper/uploaded/How to Adjust the Weight Distributing Hitch.pdf
The initial setup is critical. Park both camper and tow vehicle on level ground but not connected. Measure ground to inside trailer ball socket. Measure ground to top of ball and make that one inch higher than trailer. Tighten everything in place. Then, when connecting both units use the bars to pull units level. Do that by adjusting how close to the trailer frame the bar ends are forced by adjusting links. The tilt of the ball mount may also be tilted to adjust links needed to allow for turning of the combination unit. This should bring both trailer and tow vehicle closer to level.
coolzzy
Idaho
That trailer definitely weighs more than 6k pounds and more than likely has a tongue weight in the 800 pound range. I have a tracer air 250 ultralight with dry weight of 5k pounds and GVWR of 6200. When I tow with fresh tank full I have a 900+ pound tongue weight and am at or over GVWR for the trailer. I also have a husky centerline TS hitch and installed it and adjusted it myself when I bought the expedition (17 with HD tow). I have 1/2 to 1" sag in the back and zero rise in the front once the bars are set. The bars are extremely tight to achieve this sort of weight distribution and without a power tongue jack it would be very difficult to hitch up. With an extension foot on the jack I have to raise the tongue nearly to max jack extension (when coupled to the truck) to get the bars locked on to the saddles on the trailer.
chuck s
Based on my '07 and '17 trucks the Ford Expedition receiver has a lot of vertical slop. This allows the whole trailer hitch to tilt up ever so slightly (decreasing weight transfer) in the receiver and require more washers to push the angle back down. (Equalizer 10,000/1,000 WDH). The dealer where we bought the trailer set it up but it was really just good enough to get it home. There was never enough weight transfer until I completely removed and reinstalled the hitch. Not just this trailer and truck but on a previous completely different truck, trailer, and hitch.
Recommend setting this yourself by methodically following the instructions. Few setups I've seen actually transfer enough weight.
The process will slowly and incrementally tune the hitch to the truck and the trailer. Plan on at least a couple of hours if you're lucky.
Example: The process will require several major adjustments. As soon as you get the weight transfer correct the hitch will be too high (or two low) and you'll need to move the hitch head down (or up). Several bolts to move it. Then the weight transfer will be wrong so you gotta adjust that. Then the ball will be at the wrong height. Each adjustment will get ya closer to the right setting. If you know someone with the same trailer, hitch, and truck use their settings as a starting point.
Do you think the minimum wage "mechanic" at the trailer dealer can do this better than you? If it happens quickly it's probably wrong.
-- Chuck
CaptOchs
Rochester NY
Congrats on the camper. I have a 2003 Expedition. My last Keystone 27BH camper was about the same size. Last year I bought a Keystone 270LE 33ft/7000# camper and upgraded to Reese Dual Cam WD. My tongue weight is around 825#. At first the sway was so bad it was like I didn't have any WD set up. I took it back to the RV place and they adjusted it again. It's rock solid now. In fact, it handles better than my 28ft/5500# camper ever did. They charged me $90, but that's cheap compared to losing control and wrecking on the highway.
My advice would be to let the RV dealer adjust the hitch. When it comes to your family's safety, it's not something to try and adjust by yourself. I'm a do-it-yourself person, but I decided to leave this one to the experts.
Some other advice:
  • If you WD has chain & stirrups, take a zip tie and mark the chain link that connects to the stirrup so next time you know which one to use.
  • Watch your tire pressure on both truck and trailer. I run around 45 PSI in the truck's rear axle per RV's dealer's recommendation.
  • There's a "Keystone RV Trailers Owners Group" Facebook group where people share good info about their campers or where to camp. It's a closed group, but anyone can request to join.
