No Oil in the heads after replacement
metaldrgn
somewhere
From experience, more than likely you problem was induced when you did all that maintenance. Maybe you pulled an oil galley plug or something like that? Maybe the new gasket has a plugged path that the old one didn't.
Did you use white lithium grease or Lucas heavy duty oil stabilizer for the rotating parts that need oil so you don't run them dry?
L
ltramon45
Ocoee, FL
Did not use those products. When I got the heads back i reinstalled them. It is beginning to sound as if I have to tear the heads down again
metaldrgn
somewhere
Mine has had a singular knock for 60,000 miles and still runs, though it is getting worse. I use Lucas oil stabilizer with my oil changes and that does help. For some reason, one lifter is not getting oiled like the others. I have heard it in other 5.4's too but I have not torn my motor down yet so not sure what causes it. So it did not knock before you did the work?
My '98 EB had a slight knock that got worse and worse till the engine threw a rod. So be careful! I looked under the expedition because there was oil under it and sure enough there was a hole in the bottom of the oil pan! I didn't know how bad it was because it was over grass.
L
ltramon45
Ocoee, FL
I am parked on the drive way. compression test maybe? drain the oil? I just dont know what to do. Hell I might have to get a mechanic involved. about to give up
metaldrgn
somewhere
Well first lets look at what's not working correctly. There should be diagrams of the oil system and basically you need to make sure one of the paths isn't blocked or open and bleeding back into the pan or out of the engine.
Temple, Georgia
Your missing the big picture:
You need to determine if the oil pump works. You do this with the mechanical oil pressure gauge. It will most likely tap into a point close to the oil pump vs farther away. If you have pressure at that point the head gaskets are on the wrong side. If no pressure then the pump is toast.
remember - kiss - keep it simple stupid (not intended as an insult)
L
ltramon45
Ocoee, FL
Ok now its making sense. stamp11127 I will check that with a mechanical oil pressure gauge. and stamp i like the KISS method except lately I have not been using it wisely. no insult taken. I will report tomorrow evening as i work until 5pm
metaldrgn the engine is a 5.4
thanks. keep sending ideas and thoughts, everything helps
metaldrgn
somewhere
somebody on another forum suggested it might be air in the system that needs to be purged out. any thoughts?
No it's not air.
Most likely your pump is fine. Again I can't stress enough that because you just did all that work and you are now having problems that you induced somehow (this is just what's common when you have problems after doing work like that). Also if your oil gauge is reading 0 and it's working correctly, hooking a mechanical gauge somewhere else in the line is also going to give you a 0 reading because it's all flowing out somewhere else unless you block it at another point.
Added legend to previous post
I haven't rebuilt or even pulled the heads off a Ford, just the intake and that didn't have oil passages. Usually there isn't any weird connections that come off or need to go on for a head gasket change so that is odd you are having this problem. I'm not saying it can't be the pump, I'm just saying to focus on the work you just did as the possible root cause.
L
ltramon45
Ocoee, FL
The regular gauge is working. So it leads me to believe that its not the pump. Maybe checking with an external gauge might not hurt.
So what are my options - tearing it apart? or adding something like Marvel Mystery Oil or Lucas products. Also thinking about draining the oil and pouring it back in.
metaldrgn
somewhere
Is the oil gauge showing pressure? good pressure?
Did you actually pull the valve covers to see if there was any oil or lack of for that matter?
L
ltramon45
Ocoee, FL
The regular gauge is reading normal pressure. It could be clogged. I looked in the oil fill tube and see dry no oil. I have not pulled anything apart yet.
metaldrgn
somewhere
I would take off the valve covers and see if one or both are or aren't getting oil. Or just take off the valve cover that's easiest to pull for starters and let us know what you find.
Oh yea I forgot, this is a OHC setup, you don't have lifters. If oil pressure is good, I think you may have another problem if it's noisier after your rebuild. Did you torque your cams down with a torque wrench? Did you put all your hydraulic lash adjusters exactly where they came from?
toms89
technical advisor
MD
The gaskets are side specific and should be marked for which side they go on. If they're on the wrong side that could block the oil passages.
Misspelling brought to you by tapatalk
^^^^ That was my thought as well. Would make sense with the work you performed.
@ Stamp.. the oil pump on these motors are located on the front of the block. Goes over the crank behind the timing gear so dropping the pan no longer gives access.
metaldrgn
somewhere
Now that I think of it I would assume the hydraulic lash adjusters work like the hydraulic lifters so if they weren't getting oil your rocker arms would make more noise. If they or the rocker arms weren't reinstalled in the same spots, one may be just a little bit out of tolerance causing noise. I would still pull that driver side valve cover and check for oil.
