stamp11127
The ignition system is a different circuit than the starting circuit. Focus on one issue at a time.
Exactly what i was going to say. It HAS GOT TO BE an expy that is the same model, made same EXACT YEAR, but do remember, if it is a build date of 06-12/2003 (mm/yyyy) its considered a 2004.1st post: All it does is crank and that's it.
6th post: It's a '03 5.4L and it was the one in the kick panel and yes it was identical to the original, made sure of that before I bought it. New or used? Same part #s?
I do hear the fuel pump kick on like it should but I cant test fuel at the engine or spark since it wont even crank, everything turns off like it should to start but no crank or anything just dead silence other than the fuse box making its noise ...
doesn't need to be running to check fuel pressure
Now it isn't cranking but in your first post it was?
Fuse box making noise? They don't make noise other than light clicking as the relays turn on/off.
Without seeing the part #'s for both boxes you have the same symptoms other members have had when they switch to the wrong central junction box. Even though they look the same there are internal wiring differences that make them specific to individual models/years.
