OBD II port issue
Fubar
Tucson AZ
my obd II port will not activate. I'm plugging in an sct xcal2 and it won't activate. I tried it on another expeditoon and it came on so it's not broken. I read somewhere that the fuse that powers the power sockets also powers the obd II port so I changed them out. It still won't work. Any ideas? It's a 98 5.4 4x4
Canadian Expy
Toronto ON
Did you check to see if there is power at the port?
I have heard of OBD ports not reading but I can't seem to remember why???
Sorry, good luck
F
Fubar
Tucson AZ
It won't power up the xcal, but the power outlets are working just fine
F
Fubar
Tucson AZ
I believe so, it won't even power up when plugged in. We tried it on an f150 and it came on right away
Canadian Expy
Toronto ON
Are you sure that the fuse isn;t blown also make sure it's getting the reqiured amount of power( multi metre) not just power( light probe)
F
Fubar
Tucson AZ
I replaced both fuses for the power ports in the dash. What other fuse could be tied to the obd II?
JUST4FUN
Admin
Moderator Administrator
Il
Look for the cigarette lighter fuse
Temple, Georgia
Looking at the under dash DLC connector, which should be wider at the bottom than the top, the lower row of pins are numbered 1-8. The upper row is numbered 9-16. The numbering order is from right to left on both rows. Pin 16 is hot at all times, has two fuses, one in the central junction box (20A #3) the other in the battery junction box(50A #103). There is a connector between the two fuses - one of the 3 large ones on the firewall.
The grounds are pins 4 & 5.
This is from my 99 Expy manual and should be the same on yours.
F
Fubar
Tucson AZ
in my owners manual the i was told to replace fuse 3, 5. both are mini 25A.
Temple, Georgia
I downloaded the owners manual for the 98 - 1st printing.
The only entry for the dlc is in the passenger compartment fuse panel, location 12 rated at 5amp.
