Has anyone been able to document a drop in knock retard after installing a catch can? My ls1 car had knock retard with the Oem setup. I added a catch can system built with some parts store stuff and cut that right down to zero. Had two filters and a catch can.
Can would have quite a bit of oil every so often. Filters would get misted enough to mess flow up and I could tell they needed changed because the way the engine ran.
What model # is the UPR can on your ‘19? Was it “plug and play”?
Compressed air gets hot. Hot air, absorbs water. Ethanol absorbs water. Boosted engines dilute oil, with gas. Water vapor, fuel and oil is what gets sucked into PCV. A normal running engine should burn it off. Worn rings and valves, let blow by into crankcase. Excess crank pressure run through a catch can, will help. Racers use them, but are running high RPM and boost. The Expedition should not need one.
