TactialMonkey
Ok so my rig is just sitting in the drive way till I order up this tranny so it gives me time to redo the electric system to fix the PATS issues. So the question is my 99 has full blown PATS and as I understand the 97-98 versions do not send an ignition interrupt signal like the bloody 99 does causing her to not start. So I know that the ignition cylinder and the gauge cluster and the PCM will have to be changed out from a donor truck but will i need the GEM as well? And any other major electric things needed to swap to a more primitive electric system? Are the connectors the same between the years? Will a PCM from a manual truck be better as I’m swapping it. Thanks for the help in advance. Chase
