Starkman's Expedition - Big Red Elephant
West Covina, CA
What kind of swaybar disconnects do you plan on using? As you most likely know, most upgrades that are available, if any, are geared towards F-150s. I still haven't seen any sway bar disconnects and have also thought about this. Will you also be disconnecting the rear sway bar?
Starkman
Starkman
Arvada, CO
I may just take the bar off. I ran my Explorer that way for years and because I’m old I don’t drive too fast and never had an issue. I looked at using a link from a new Ford that has a ball joints instead of the factory straight style. Then I was thinking I could cut the shaft and put a collar over and pin it so it can be removable. Explorer Tom did that on his truck (IIRC) and it should work. I may just remove the rear bar, it’s really small and I’m not sure if it matters too much.
ExplorerTom
Colorado
I never had disconnects on my Expedition. My Explorer had disconnects meant for a Jeep. But then I got rid of the sway bar completely.
