I did a quick search before posting this and only found one thread that was related but it didn't fully answer my questions.
I have a 97 xlt w/o air ride and I'm thinking about doing a total suspension rebuild (front and rear) including bushings, shocks, ball joints, tie rods, etc. I've read in numerous places online that these items wear and need attention. I'm experiencing some mild clunks and weird vertical play in the steering wheel that is only noticeable when you hit bumps. The wheel and column are not physically loose when I attempt to move it so I figure something is worn out on the front end.
From a visual inspection the stock bushings are dried out, cracked, and shot. I have 135k on the clock and figure the ball joints (which are stock) need to go as well. While I'm on the subject, they started to squeak a year ago which I combated by buying a needle and injecting each one with grease which eliminated the squeaking. I have been doing this every 5k for the past 10k and figure I'm only slowing the problem down...
Moving on, I'm also suffering from rusting trailing arms and panhard bar and know those might be worth a removal and sand blasting to either re-coat with POR-15 or just replace.
My question is this: given the current list of items I'm looking at addressing, is this a DIY job considering I don't have an impact gun? I realize I'm going to be encountering some bigger bolts that will require some torque to move and thinking realistically, I'm not sure if I'll be over my head. I consider myself mechanically competent and I'm confident I could do the job such as renting the proper tools (ball joint press tool for example) but I'm also concerned that I might not be able complete it as this will be a one man job.
Thoughts? Experiences? Comments?
