Not to mention to have your engine built like that, you are going to wind up spending the same amount, you have to have it tuned, pay for the labor etc. The Edelbrock makes it something you can do yourself and it will be made for a stock engine and comes with the programmer.
Hi
I bought a Edelbrock supercharger in Aug 2010 (at that time the only kit available was for the F150) I installed it om my 2008 Exedition. Had to do a few small modification.
But the biggest problem is the software. They supplied me with a STC handheld programmer, but the file does not see the Expedition ECU. I found out from STC that the F150 and Expedition does not share the same ECU.
The Edelbrock web does list the Expedition now, but the software is still the same as last year. They did send me a file on e-mail that I could upload to my Expedition, but the tune is realy bad. My car makes the same power as a standard Expedition.
I had the car yesterday at a local tuner in Dubai, but his HP tuning software could not read the Expedition ECU.
I got to a point where I want to restore my car to standard again.
Any good advice would be appreciated.
I just picked up the Expedition on Saturday. It has good pep, but isn't what I was expecting. It seems to be picking up the more I drive it. I am taking it in soon for a couple dyno runs at a shop here locally. I'm curious what it's putting out. It won't spin the tires, and that has me curious too. Although I had a diesel truck putting out 450 hp and over 700 lb-ft of torque and it just hooked up too, so who knows.
I don't have a boost gauge yet either, and they can measure boost on the dyno. There is very little whine. To be continued.![]()
Hi Tom, I was hoping you would chime in.It is 4wd. I have been running in 2wd, and deactivating the traction control. With newer cars though, it seems there is always some sort of traction control in place, even with it deactivated.
What boost are you running? Inside, mine sounds pretty similar to the Mustang video that was posted earlier.
Don't get me wrong, it's pretty fast, and deceptively so because of the size of the car. I had a 6.2L Denali before this that had a custom tune, intake, and exhaust. This is faster than that.
What should I expect to see at the rear wheels with Edelbrock claiming 475hp and 504 lb-ft of torque?
I had my dyno runs today. All three runs were nearly identical. 370 rwhp, and 435 lb-ft of torque. The guy running the dyno said that was pretty good considering the losses in a 4x4 drivetrain. I'm satisfied. It verified it's performing as they advertise.
Now I need to get the trans shifting sorted out. Hopefully 5 Star can help me with a tune. I'm also going to add a Magnaflow exhaust at some point. I think that will give some fair gains over the stock exhaust given the power it's putting out.
Here is JDM Engineering, they specilize in Fords. Here is their site and they are very helpful. http://www.teamjdm.com/
jdm told me they dont have anything that would work on my ford expedition 2011 a while back, wonder if that has changed
