Hheeeelllpppp!!!!!!
Whack
St Louis
Can we see a pic of the plug part that came out of the #8 and a shot of your extractor tool?
My thinking is enough of the reverse is available, but the bit isn't going down enough...
or...
The extractor reverse threading is worn enough not to catch.
Are you using the Lisle 65600?
B
bigred-262002
I have easy outs but they are too short. I did try a tap with no luck. We are thinking outside the box now an started it brought it up to running temp an cleaned the puller an the peace an put a small amount of JB weld it the end of the puller and used a down force with a pry bar letting it sit. I will go back out in a bit an try again. I figure a $120 puller is cheaper then pulling the head. I will take a picture an post it when it comes back out of the head. Once again thanks guys you all rock.
04EB
so how does the mustang ride
If your asking me, it rides good, didn't really notice a handling difference from the 4.6L that was in it. Did notice quite a boost on the ass dyno though!
B
bigred-262002
Ha i wish. The JB weld didn't hold. So now I'm out of ideas. The picture is of one that i pulled out of another cyclinder
B
bigred-262002
Ok i have lost my mind. I just drove the hell out of it thinking if it got hot plus running that it might loosen up an pull out. But just my luck it didn't. Oh well looks like I'm pulling a head this weekend.
Experez
Tx
Napa makes the perfect tool for about 100 dollars, you need to try that before you pull the head!!! It even has lifetime warranty, just go to the store and tell them what you have 5.4 3valve
Jeff532003
Massachusetts
Just a thought but you might want to ask a machine shop what they think before you pull the plug. They would be the most skilled people at getting something like this out without pulling it.
B
bigred-262002
I will have to check out napa an see what they have. I called a local machine shop an they said is the only thing they know to do is to pull the head an remove it from the bottom. So no help there.
04EB
Did that TSB link I posted help at all? I've only read it and never had to apply what it says to a spark plug that was broken off. Just wondering if it's useful information or not.
B
bigred-262002
Every little bit helps. Any an every info I can find I will look at. It did give me an idea that I might try tonight. It an other stuff I have seen says it helps to flush the carbon out before pulling the plugs. Well umm to late but still worth a try . I was going to stop on my way home an buy some sea foam an run it thru the sntystem an maybe it will knock the carbon an maybe lube it from the inside an try again. Cant hurt right? I'm starting to run out of time an if this doesn't work as of tomorrow the head is coming off. The only bad part is that is my only car an being a single dad I need to be able to go places. Oh well living the dream an the bills to prove it. Lol.
B
bigred-262002
Well in ran the sea foam thru it but that all i did. I had other things to do so in didn't play with it. I will let you know tonight if it helps.
