jeff kushner
Thanks for the straightforward answer Loki.....makes my life easier !!!
sorry for the hijack guys...thanks....
jeff
jeff
Spent some time today looking for the secure idle address. Frustrating.
As others have already discovered, the BCM 726-42-01 address does not apply to secure idle for 15-17MY Expys. From what I can find it does apply to 15+MY F150's, Raptors, super duties, 11+MY Explorers, 16+MY Fusions and possibly the Flex and Mustang as well.
Comparing BCM addresses, I was hoping maybe the offset between values for common features (like the double honk) would be the consistent throughout the module. i.e. F150 double horn honk is 726-41-02 and Expy is 726-16-01 giving an offset of 25. However, DRL's (fogs) for the F150 is 726-45-01 and Expy is 726-11-01 giving an offset of 34. A simple offset calc that points to the correct address on ours would have been nice. But nope.
So now I'm on the hunt for the full field of data from a F150 for the 726-42-01 address. I've already PM'd a few guys on the 150 forum to see if they have time/desire to share that with me. My hope would be to simply compare those values to the Expy BCM fields and see if I can find a match. This could be a total dead end but I figure it's worth a try.
Also, if anyone here with a SSV from the past four years has access to FORScan and would be willing to send me your BCM file, that would be immensely helpful.
Hopefully this doesn't end up to be a wild goose chase. I still have hope because the 2017 SSV fleet brochure specifically mentions secure idle as an option, so at least in the 17MY vehicles it should be possible.
Sorry for my ignorance but what is the Ford IDS software package?Has anyone downloaded and installed the Ford IDS software package (v108.01)? Can it be utilized with the same OBDLinkMX?
Can you post a link to it?Happy New Year guys and gals!
With 31 pages and counting in this threat, I'm too impatient to read through it all, so can someone confirm the FORScan 2015 spreadsheet AllBoostNoEco (thanks dude) posted on Google Docs works module-for-module with the '17? I just received my OBDLink MX yesterday and need to turn off the double honk ASAP (it's freakin' cold outside)!
This is the one that I have that works if it is the same as one you are referring to you are good to go.
- The auxiliary climate control system is functional whenever the instrument panel mounted HVAC module is in any mode except OFF.
- The auxiliary blower motor recirculates the air inside the vehicle. Outside air is not available to the auxiliary system.
- Air is cooled and dehumidified by the auxiliary A/C evaporator core only if the front (main) climate control system is operating in a mode that requires A/C compressor operation.
- The temperature blend door and the auxiliary mode door are controlled by electric actuator motors.
- Movement of the auxiliary temperature control between cool and warm causes a corresponding movement of the temperature blend door to mix air flowing through and around the auxiliary heater core.
- Movement of the auxiliary mode control between PANEL and FLOOR causes a corresponding movement of the auxiliary mode door to direct airflow between the panel (headliner) registers and the floor duct.
Hey guys, has anyone changed their splash screen ? I’d love to change mine to “GT” or “Raptor “ .
