I can state for a fact that I cannot put my 2018 Expedition in gear after it is started and the key is taken out of range. I tested it last night.I don't think it prevents you from putting it in gear.
I see, thanks for the clarification.Yes, I know. I was referring to edizzle's Explorer, not your Expedition.
Yes it does, but as I get older and have had problems with carpal tunnel, I have lost some sensitivity in my fingers and have troubles with those switches.On the auto up and down, is it not like the front and built into the button? Press a little/press a lot
10-4 makes sense.Yes it does, but as I get older and have had problems with carpal tunnel, I have lost some sensitivity in my fingers and have troubles with those switches.
Dennis
Number of flashes on the turn signal.. went from 3 to 4.What did you change in the SCCM?
also my value was 7, which seems odd, as most values referenced in the F150 forum were default 6 (number of flashes.), so i went to 9 to get the 4 flashes, keeping the last bit as a 1. no issues .
