AllBoostNoEco
The Expedition didn’t get a HSW until the ‘18 model, regardless of trim level.
On a 2017 rig has anyone experimented with 726-06-01?
Or 726-48-01?
I would think this is only available for police departments and is probably a separate system installed on the vehicle at departments requestView attachment 23418
So I found a 2017 brochure describing the “Police Engine Idle” feature on Explorer and Sedan Interceptors.
It mentions a button you have to push, and scrolling down to the Expedition SSV there is no mention of it as an option.
I'd like to figure out how to make the rear climate control follow the front on Auto.
No luck.No luck.
I can get Auto to display on the rear control (see pic), but I can’t get the rear to follow the front Auto setting.
I tried various combinations of modifying the following 2 lines...separately and together:
APIM 7D0-01-02 xxxx xxxx 0xxx
changed the 0 to everything from 1 to F and got various combinations of Auto/No Auto/No rear temp control on Sync 3 screen for the Rear control setting
HVAC 733-01-02 xx0xx xxxx xx
changed the 0 to 4 (automatic) and I could hear some click noise in right rear of Expy like some setting had been changed, but didn’t notice any changes to controlling the rear air
Anyone else investigating this feature?
Is it possible that using AUTO mode for the rear is designed to disable the rear controls in a vehicle that’s programmed that way originally but it’s not doing that in yours?
Maybe try either disabling rear control through the HVAC or setting it to front control only by changing 733-01-01 to x0xx xxxx xx (disabled) or x1xx xxxx xx (front control only); and see if that makes a difference?
I have MFT, which doesn’t mention the possibility of auto in the rear at all, so I don’t think it will work in mine.
Anyone have any luck with Boost or adding menus to the right side dash display (climate)? I tried messing around with a Ford IDS today and found nothing
When it shows that rear auto screen, does it actually show a numerical temperature setting like it does for the front climate control? Right now I just have high and low and anything in between. I haven't looked on the rear control panel to see if there is an auto setting.View attachment 23486 No luck.
