How does this setup look for weight distribution...anyone able to get no sag on rear?
Rosko
Wyoming
Hi all. I spent the better part of the afternoon transferring my Equalizer 4 point sway/dist hitch from my 3/4 ton Yukon to my 2017 expedition EL.
I never felt like I was able to reduce the squat on the back enough...if I setup the WDH to put more weight to the front of the Expy, it would just lower the front end too much and the rear wouldn't raise up. I ended up settling on about 1/2" to 3/4" squat in the rear, and the front remained about the same height as unloaded.
I'm guessing the IRS is just going to be setup this way...and I probably won't be able to get the rear to have zero squat (without passengers).
shane_th_ee
Seattle
If I setup the WDH to put more weight to the front of the Expy, it would just lower the front end too much and the rear wouldn't raise up...
Are you expecting the rear of the expedition not to settle at all when you attach the trailer to it? Or am I reading something incorrectly? And do you have the auto-leveling suspension in yours?
coolzzy
Idaho
That looks correct to me. My expy squats the same amount in the rear with my wdh setup correctly and has no change in height at the front wheels. The IRS is a bit squirly in windy situations on the highway compared to a solid rear axle. I'll be looking at a firmer sidewall tire for next season, the oem tires are very soft in the sidewalls even when running max inflation pressure.
R
Rosko
Wyoming
Hi Shane. Yes, while I was basically unloaded in the Expedition I was hoping to just get it corrected to not squat at all with the WDH setup, then when I load my family in there it'll squat some.
I think it'll just have to do the way it is, I have the limited without the auto leveling shocks. I could get some air support but I'm not sure it's really worth it yet.
R
Rosko
Wyoming
Yeah compared to my old 2004 3/4 ton Yukon XL, the expedition wiggles a lot more in my testing on the interstate.....but it's so much more comfortable/powerful/better braking I think I can live with it (time will tell).
My old Yukon is a beast though, I've taken this trailer to Yellowstone through Wyoming winds, passing big rigs at 65mph with insane winds and it never budged....was so solid. I'll just have to get used to the wiggle again (I had a Sequoia at one point with the IRS wiggle).
shane_th_ee
Seattle
Aren't you adding many hundreds of pounds to the truck when you hitch up the trailer (aka, the tongue weight)? Sure, the WDH will move some weight back to the trailer and some to the front axle, but the "goal" of the WDH is to split the tongue weight between the steering and drive axles. Which means you'll have added a significant weight to the rear axle (1/3-1/2 of the trailer's tongue weight). Maybe that wasn't enough to compress the 3/4 ton suspension on your old Yukon, but it's going to compress your new 1/2 ton suspension. My recommendation would be doing a 3-pass weigh of your rig on your way out of town when you go camping the next time...
R
Rosko
Wyoming
Thanks Shane. I'm assuming by 3 pass you mean....weighing my expedition with gas/kids/cargo by itself, then weighing the trailer uncoupled and loaded, then weighing them both together on the cat scale to get how it distributes weights on the 3 sets of axles? That is my plan, though I'm not sure when I'll get around to it with school almost starting here for the kids.
The Yukon actually squatted an inch or two unloaded too...but it starts out so high it was a different animal. It helps to have 5 heavy duty leaf springs in the back over a straight axle :). I think the cargo limit on the Yukon is 1000lbs more than the Expedition, and the axles can handle a bit more weight too (obviously)....but it rides like a box of rocks compared to the expedition LOL.
shane_th_ee
Seattle
Close. You want to weigh the Expedition with wife/kids/cargo/trailer/everything just like you'd tow to go camping. And you want to use a real CAT scale so you can get all 3 axle weights (steer, drive, and trailer) at the same time. Then you want to disconnect the spring bars and weigh the whole thing again. Finally, drop the trailer and weigh just the truck with everything and everyone in it. From there you can figure out trailer weight, actual tongue weight and what the WDH is actually doing (or not doing).
R
Rosko
Wyoming
Yeah it should be a fun exercise. When I just weighted our entire setup at the CAT scale last time with the Yukon, I only weighed everything together with the 3 axles. I was able to at least figure out if I was overloading the rear axle, but it would be better to know how much the bars are actually working like you mentioned....though the front axle limit is usually lower than the rear anyway.
If I had to guess, I'm not going to be able to change my bars/hitch to get it setup much better because the front end will drop with any more torquing. But it will be nice to understand how to load the trailer/where I need to pack things to make sure I'm not overloading the rear axle.
Thanks!
8131full
Las Vegas
View attachment 26145 View attachment 26146
Whats that trailer weigh fully loaded (or at least how you go down the road)? Looks big!
