4th Gen Expy FORScan Modifications
17LimitedExpy
TN
Hello 17LimitedExpy
You have in your document in section "NotPossible" Reverse Tilt Mirrors.
This works on my 2018 Expedition Platinum (without any changes)
Try this for use the Reverse Tilt Mirror:
1) Select the mirror you want to tilt by pressing the mirror button
2) Put your vehicle into reverse (R) and let the mirror automatically tilt until it stops
3) Return to drive (D) or park (P). The mirror go back to his normal position
Note: You can press the mirror button to deactivate Reverse Tilt at any Time
Try this for Reverse Tilt Mirror Calibration (instructions from PlatinumOwner from F150 Forum):
1) Switch the ignition on
2) Press the memory button
3) Select the mirror you want to adjust
4) Put your vehicle into reverse (R) and let the mirror automatically tilt until it stops
5) When the mirror is in its tilted position and is no longer moving, adjust it with the controls
6) Hold the memory button for 5 seconds to save the setting
7) Press the mirror button and return to park (P)
8) Hold memory button again
Can you please add this to your document. Thanks
APCO_P25
Thank you. That “not possible” section is mostly for the 2015-2017 Expeditions...I’ll update the title to reflect properly.
benyl
Calgary
Just to confirm...did you have to change all 3 lines to get the Blue Theme?
The line 7D0-02-01 you mention sets the GT Startup screen...so did the other 2 lines you write about make the screen blue?
Thanks.
I just did all 3. Didn’t try just one and test.
JohnT
Canada
Is it possible to turn on the reverse dip mirror function for a non Platinum 2018?
benyl
Calgary
I don't know if any of you have changed your tires size, but if you have, you will run into a P160A DTC due to a mismatch between the PCM and TCM compared to the value you put in the BCM.
The latest beta 18 version (I am sure it will come out soon) will address the problem for the 2018 Expy.
17LimitedExpy
TN
There is a 'PCM Re-Learn' feature in FORScan...that should clear the P160A error.
BenG
Does anyone know the Trailer Brake Controller code for 2018 Expedition? I tried everywhere but I am not able to find it.
rcompart
rcompart
IL
Still not possible to change anything in the IPC or DDM/PDM with the newest beta. :(
On another note, I did play around with the steering wheel heater temps.
Code:
HSWM 714-02-01: 023C 3C3C xx - 60ºF (15.6ºC)
                023D 3D3D xx - 61ºF (16.1ºC)
                023E 3E3E xx - 62ºF (16.7ºC)
                023F 3F3F xx - 63ºF (17.2ºC)
                0240 4040 xx - 64ºF (17.8ºC)
                0241 4141 xx - 65ºF (18.3ºC)
                0242 4242 xx - 66ºF (18.9ºC)
                0243 4343 xx - 67ºF (19.4ºC)
                0244 4444 xx - 68ºF (20.0ºC)
                0245 4545 xx - 69ºF (20.6ºC)
                0246 4646 xx - 70ºF (21.1ºC)
                0247 4747 xx - 71ºF (21.7ºC)
                0248 4848 xx - 72ºF (22.2ºC)
                0249 4949 xx - 73ºF (22.8ºC)
                024A 4A4A xx - 74ºF (23.3ºC)
                024B 4B4B xx - 75ºF (23.9ºC)
                024C 4C4C xx - 76ºF (24.4ºC)
                024D 4D4D xx - 77ºF (25.0ºC)
                024E 4E4E xx - 78ºF (25.6ºC)
                024F 4F4F xx - 79ºF (26.1ºC)
                0250 5050 xx - 80ºF (26.7ºC)
                0251 5151 xx - 81ºF (27.2ºC)
                0252 5252 xx - 82ºF (27.8ºC)
                0253 5353 xx - 83ºF (28.3ºC)
                0254 5454 xx - 84ºF (28.9ºC)
                0255 5555 xx - 85ºF (29.4ºC)
                0256 5656 xx - 86ºF (30.0ºC)
                0257 5757 xx - 87ºF (30.6ºC)
                0258 5858 xx - 88ºF (31.1ºC)
                0259 5959 xx - 89ºF (31.7ºC)
                025A 5A5A xx - 90ºF (32.2ºC)
                025B 5B5B xx - 91ºF (32.8ºC)
                025C 5C5C xx - 92ºF (33.3ºC)
                025D 5D5D xx - 93ºF (33.9ºC)
                025E 5A5E xx - 94ºF (34.4ºC)
                025F 5F5F xx - 95ºF (35.0ºC)
                0260 6060 xx - 96ºF (35.6ºC)
                0261 6161 xx - 97ºF (36.1ºC)
                0262 6262 xx - 98ºF (36.7ºC)
                0263 6363 xx - 99ºF (37.2ºC)
                0264 6464 xx - 100ºF (37.8ºC)
                0265 6565 xx - 101ºF (38.3ºC)
                0266 6666 xx - 102ºF (38.9ºC)
                0267 6767 xx - 103ºF (39.4ºC)
                0268 6868 xx - 104ºF (40.0ºC)
                0269 6969 xx - 105ºF (40.6ºC)
                026A 6A6A xx - 106ºF (41.1ºC)
                026B 6B6B xx - 107ºF (41.7ºC)
                026C 6C6C xx - 108ºF (42.2ºC)
                026D 6D6D xx - 109ºF (42.8ºC)
HSWM 714-01-01: 1xxx xxxx xx - No steering wheel heater timeout
                Bxxx xxxx xx - 15 minute steering wheel heater timeout
                Fxxx xxxx xx - 30 minute steering wheel heater timeout
Artie
Georgia
Code:
What’s the default temp set at?
jpwiseman
