4th Gen Expy FORScan Modifications
rcompart
rcompart
IL
Mine was originally at 80°F. I’ve been playing around with the temps over the past few weeks and found 90°F to be a very pleasing temp. Warm enough that it feels almost therapeutic but not too warm that my hands start sweating after driving for a while.
East-TN
Air Force
TN
Just be aware...setting the temp higher may shorten the life of the heating element.
Artie
Georgia
Thanks for the info! I don’t think I’m gonna change mine, it doesn’t get super cold here so I think 80° is good enough for me.
rcompart
rcompart
IL
The element has a very broad amount of current it must carry based on the wire cross-section, the total overall length, the number of parallel paths, the voltage being applied and the amount of heat lost to the surrounding materials. Assuming the only variable that changes is temperature, it would still have to be designed to carry the maximum allowable current when its -40°F to bring it up to 79° regardless of whether it’s set point is 80° or 90°. The temperature of the steering wheel element is probably 20-30° hotter than the set point upon starting to warm the wheel and gradually tapers off as it approaches the set point. Taking all that into account, the number of heating cycles and the environmental operating conditions of the steering wheel will have a far greater and more direct impact on its longevity than the amount of current carried through the heating element.
East-TN
Air Force
TN
Ok...can you summarize what you’re trying to say :)
rcompart
rcompart
IL
He said you're wrong. [emoji6]
Not what I said. Just that some people may be apprehensive to increase the temperature to something more desirable because they think it will result in a considerably shorter life span. And in 17LimitedExpy’s defense, he said it may shorten its life, not will shorten its life.
twernst
Manahawkin, NJ
Hello 17LimitedExpy
You have in your document in section "NotPossible" Reverse Tilt Mirrors.
This works on my 2018 Expedition Platinum (without any changes)
Try this for use the Reverse Tilt Mirror:
1) Select the mirror you want to tilt by pressing the mirror button
2) Put your vehicle into reverse (R) and let the mirror automatically tilt until it stops
3) Return to drive (D) or park (P). The mirror go back to his normal position
Note: You can press the mirror button to deactivate Reverse Tilt at any Time
Try this for Reverse Tilt Mirror Calibration (instructions from PlatinumOwner from F150 Forum):
1) Switch the ignition on
2) Press the memory button
3) Select the mirror you want to adjust
4) Put your vehicle into reverse (R) and let the mirror automatically tilt until it stops
5) When the mirror is in its tilted position and is no longer moving, adjust it with the controls
6) Hold the memory button for 5 seconds to save the setting
7) Press the mirror button and return to park (P)
8) Hold memory button again
Can you please add this to your document. Thanks
APCO_P25
I tried this the tonight and could not get it to work or calibrate. I followed the directions, my mirrors never tilted down. Has anyone else confirmed this works?
Thanks,
APCO_P25
Switzerland
Thanks,
Hello twernst
On my Expy 2018 Platinum it works fine :)
You must calibrate the mirrors first.
Try this after the first calibration: put your gear in reverse, push the button for your desired mirror and than it works also.
twernst
Manahawkin, NJ
Hello twernst
I will have to try the calibration again, as I tried it both ways you outline. The mirror never tilted down during the "calibration" as you outline. Perhaps it has something to do with market geographic settings. I have had this feature in all my other vehicles in the past 10+ years so I was very surprised to see it not on the Plat '18 Expy.
Did you do any other mods like Forscan to get this to work, or just the calibration first?
Has anyone else done it successfully here in the states?
twernst
Manahawkin, NJ
Can someone tell me if the extended license for FORScan would work with a windows tablet, such as the Surface? I have Macs and need to buy a Windows platform and am trying to decide between a budget laptop or something that might have future value. Right now the only thing “pc” will do is FORScan related.
Got my OBD scanners this week and was hoping to take advantage of the “Black Friday” deals tomorrow.
Thanks for your help.
5150 pops
I'd like to take this opportunity to thank @17LimitedExpy @rcompart and everyone else who has and still is contributing to the Forscan thread.
As a direct result of those contributions I'm finally able to stop ruining my underwear from ******** myself, everytime I get out of the expedition while it's running, and closing the door, with the fob in my pocket.
Additionally, disabled the Auto Start/Stop, even though it would seem reasonable, that I would be used to it by now, or second nature to push the button after starting the engine, I continue to forget, and my blood pressure spikes, momentarily, as I stop at an intersection/red light, until I realize, I forgot to disable it after starting the vehicle.
To complete the trifecta, I enabled auto relock, when the vehicle has not been breached once unlocked.
I was pleased to learn that the truck is programmed from the Factory to lock out the transmission selector, unlike on some other models where they were not, at least according to forum lore.
2Scoops
SC
Just want to confirm this method does work. I have a 2018 Limited that I just programmed to do this on. Neither of my mirrors tilted at all when I tried the first time. I did notice my passenger side mirror flicker or click like it wanted to move but it never tilted down. My first attempt was on the driver side and it didn't work at all. It just saved the setting in the down position and never went back. I went to try the passenger side with the same instructions from above and it worked. Then when I clicked back to the drivers side, it worked as well.
A little odd but it did finally work. Only thing I hate is that you have to hit the button to get it to lower. It doesn't automatically do it when you put the car in reverse. I'm wondering if there is an override for this in FORSCAN so it will automatically tilt when in reverse without hitting the button?
Mothnuts
Kansas
Has anyone tried connecting with a ‘19 Expedition? I get a message saying “Unable to identify the vehicle”. I’m using version 2.3.18 beta.
Dennis48755
Caseville, MI
Just want to confirm this method does work..
I'm having trouble piecing the steps from the previous posts, so I'll ask; how did you do this? I could not get it to work on my 2018 Expedition Limited.
...I just programmed to do this on...
What do you mean by "programmed", performing the calibration steps mentioned in your quote, or were there module changes via FORScan?
I did attempt the calibration, but it didn't help.
Thanks,
Dennis
rhk118
New England
It should work with a surface. They are full fledged PCs. I just did some programming in FORScan using my 2013 MacBook air running windows 7 in parallels without problem....the program doesn't need a ton of computing power and you might be able to save yourself some money...although must say the surface is a pretty enticing platform.
rhk118
New England
Question Viewing texts - Is there some way to code on the ability to read texts while driving?
I know it sounds stupid but I get work texts requiring a response and they come with a ton of code attached to them. Kinda funny listening to Sync3 read them, but also annoying! I just need to quick check if from work or not from work and don't want to listen to it read a 1 minute+ message.
Would it be the same code as "remove speed limit for navigation keyboard" coding that also disables the 911 calls? If so not worth the trade off IMO...if I'm reading texts then I want the car to call 911 when I eat a tree...
Also thank you all as well for posting all the coding help - just turned off the double honk, auto start/stop, and added the soft climate buttons for the seats to my home screen....total thumbs up!!!
2Scoops
SC
Thanks,
Dennis
This does not require FORSCAN. This is done just as ACPO_P25 described in his post.
3) Select the mirror you want to adjust (the left or right button to adjust the mirror)
4) Put your vehicle into reverse (R) and let the mirror automatically tilt until it stops (neither or my mirrors moved. I had to tilt them to the desired position.)
7) Press the mirror button and return to park (P) (left or right mirror button that you are controlling.)
I followed these instructions and it did not work the first time. After I tried for a second time, it worked. It's a little quirky but this process did work for me.
