What Grade of Gas are you using?
Octane rating
  • <87
    Votes: 45 49.5%
  • 88-89
    Votes: 8 8.8%
  • >90
    Votes: 41 45.1%
  • I siphon gas from the neighbor
    Votes: 1 1.1%
  • I actually drive a Prius
    Votes: 1 1.1%
  • 100+ Racing Gas
    Votes: 1 1.1%
  • Total voters
    91
Super Moderator
Super Moderator
I saw this article on an earlier 2018 thread (that and forum posts educated me on the EcoBoost). The EcoBoost does a lot of real time adjustments & control to maximize performance based on what fuel is present. So (if I understand correctly) the EcoBoost modern engine is capable of taking advantage of the premium fuel vs the premium fuel with higher octane will eliminate knock if it is occurring. If I have it right and if that makes sense.
http://stratifiedauto.com/blog/unde...ons-in-your-high-performance-ecoboost-engine/
Correct, It does adjust based on knock, and Learned OAR(Octane Adjust Ratio).
The uniqueness of the EB is that it doesn’t add power, it takes power away. It is tuned based on the higher level, and pulls timing based on OAR. That is the difference in thinking. That is why even a little E added to slightly increase Octane and evaporative cooling, sees a benefit on even Stock tuning. Especially under heavy load. It helps prevent knock and improve the OAR.
Molaf
Merica
Yes … bit of a different subject but related. All the government MPG fuel economy (not HP) testing is done with "premium fuel" .. so if you use regular fuel for your day to day driving you will always achieve less MPG (in a vehicle that can take advantage of premium fuel).
:emotions33:
Plati
Interesting, but I'm not sure what that means.
Various interpretations possible I guess.
I do see the Regular Gasoline
You know (I'm sure everyone does) you can't believe everything you read.
Anything I post is in that category too!! I try to be accurate.
Here is where I got my info.
http://www.automobilemag.com/news/octane-fuel-economy-horsepower-epa/
and its says:
"The EPA and automakers use Indolene test fuel for all (gasoline) vehicle testing, for consistency purposes," a spokesperson for the agency says. "Indolene is a high-octane fuel that meets a wide range of technical specifications."
another interesting factoid for the testing is that they dont actually measure the volume of gas consumed. they collect the tailpipe exhaust gas and measure the carbon content and calculate the amount of fuel they "figure" was used (amount of energy). maybe they added a fudge factor and calculated it to what was used if it was regular vs premium? so they might fill tank with Indolene but calculate MPG out to be representative of regular octane. i think they also add a fudge factor for the aerondynamics and rolling resistance of the vehicle. the testing was designed by F'in Engineers after all.
its all so complicated. i'm gonna have a BEER
which I can easily afford since I burn 87 octane gas
(dont care what time of day it is, I'm retired)
Molaf
Merica
Ya so the basic gist of things I'm getting from the most of the replies is that putting around town, 87 is fine. Towing and highway, 91(or 93). My BiL said the same thing(he has the 3.5 in his F150).
Super Moderator
Super Moderator
Personally, I like to have all the power available all the time, but I like power.
When I ran the numbers, with the Wife’s regular driving, I saw an increase in MPG while running 93 vs 87. Did it completely make up for the fuel cost difference, No, but it offset it, and the cost per mile was very close.
For me it was a Win/win. More power, with little impact to my bottom line. Plus, looking at logging, FAR less KR(Knock Retard) events!
