The "Auto Stop-Start" is so annoying!!!!
texevora
DFW
Just finished the install of the Autostop Eliminator. I didn't want to wait and assume that an eventual fix for the charge system error would ever be developed. Also didn't want to worry about resetting everything back to factory if the car is ever in for warranty service.
The wire harness version install is super easy. <10 mins from start to finish, and much cleaner (ie nothing hanging off of your OBD dongle). Even an idiot like me had no problem installing it.
All i used was 2 microfiber towels to avoid damaging the plastic, a 7mm offset ratchet, and a plastic pry tool.
Grey ghost
Melbourne fl
We should change the name of this forum to the i hate the auto stop-start.
even people I talked to six months ago that said oh it doesn't bother me that much I think it's handy have learned to hate it and another guy went and traded his in and got a Chevrolet. Congratulations your car is now 100% more enjoyable
Deadman
That center plastic piece is TIGHT and feels like you are breaking it while trying to remove it.
Artie
Georgia
So what is the consensus on the best battery for these vehicles? I’ve seen Northstar and Optima mentioned but checking their websites shows none that fit my Navigator... I assume it’s the same battery as what would be in a Expy Platinum. My voltage is running in the low 12’s and this is after a 500 mile drive on Wednesday. I haven’t had the dealer look at it but that will be my next move if I start to have more issues with my locks and lighting. I’d rather move up in battery quality vs replace with what I got now.
NukeLife
Charlotte
This may be old school, but I’m accustomed to seeing 13.5v on a “healthy” system.
Fozzy
Riverton
https://www.odysseybattery.com/Battery_Search.aspx
I love the Odyssey batteries. They are rock solid. The only problem is the AGM charging problem. I have yet to find any stock charging system that can keep them topped off, including my 19’ Expy. They need to be topped off at regular intervals and they will last longer than your Expy.
Artie
Georgia
So there’s just no avoiding hooking up a charger every once in a while, is this what your saying? If that’s the case then there may not be anything wrong with my battery. What should my voltage be at, over 12.2?
Plati
Wait a minute. I asked this question and several Forum posters said ANY vehicle can keep them charged. Do you know something they don't know? I'm not being snarky, just asking.
Also - you say "they will last longer than your Expy". Surely you jest? I'm still driving my 2003 Expy, they aint gonna last that long. 5 years is probably good. Sorry if your name isn't Shirley.
Fozzy
Riverton
In my experience with AGM batteries you have to top them off with a AGM charger. My Expy had the lights freaking out and would randomly flash the lights. I put it on the charger last week and it was only 30% charged. Topped it off and it is back to normal. A fully charged AGM battery is 12.65. I just went out and tested my voltage on my year old 19’ factory battery. 12.3 Volts cold and 14.9 Volts with the truck running. I would say your battery is fine.
Fozzy
Riverton
Yes, any vehicle can keep an AGM battery charged, just not topped off. This is from my experience running AGM batteries since 1990. I use to be into car audio and have had vehicles with up to 20 batteries installed. At that time Optima was the leader in the industry. Before true AGM chargers where available you use to have to trick the charger into charging a flat AGM by paralleling a standard fully charged lead acid battery to the AGM and hook the battery charger to the lead acid. I have 2 red top Optima’s in my CJ-5 that where new in 1992 still going. Pretty damn good if you ask me. (New Optima’s suck). I bet Artie won’t have that navigator more than a few years. I have ran AGM batteries in 6 dodge diesels, my CJ-5, a Ford Raptor, Ford F-150, Ford 6.7 Powerstroke,Chevy Kodiak, Polaris SXS’s and my new Can-Am X3 and none of those vehicles have been able to top an AGM battery off. The Expy is the first vehicle I have owned with a factory AGM battery. I think it’s a great choice for a vehicle with so many lights, gizmos and ASS. Very robust and can take a beating. But if you just do short trips and use ASS the truck doesn’t have time to charge your battery IMO and it shows when you hook up a charger. Go hook up your fourth Gen AGM equipped Expy to an AGM charger right now and I would bet it needs a charge. Shirley out.
Artie
Georgia
You described my situation perfectly. I am using a AGM charger so I’ll just top it off from time to time.
Artie
Georgia
We bought with the intention of 8-10 years. My wife may get the Navigator in a couple years, we need something geared more to off pavement adventures but can’t give up the Navigator because it’s just so damn good at everything else. I just don’t think the Navigator can get us everywhere a slightly tricked out Land Cruiser or Bronco could. Idk, I may get adventurous with it before too long... we shall see. Anyway, thanks for the rest of your post, lots of info and I appreciate the education.
Fozzy
Riverton
I would give it a try. And it will be interesting to see if you take your new bad a$$ trailer on longer trips if it can top the battery off. We are going to try and use the Expy to pull our boat this summer and it will see more miles that just trips around town. 8-10 on the Navi, I bet a well maintained Odyssey will last. I wasn’t talking about the stock one. I am not sure who makes the FOMOCO battery. They use to be Johnson Controls. And they cheeped out on the Optima’s.
Plati
Thanks Shirley. I've been trying to learn about batteries for the past few years. Picking up a little here and there. Didn't know AGM's been around that long. I check my battery voltage every once in a while and it seems to me like my 2 Expy's don't keep the old style (is it flooded?) batteries topped off either. But its probably dependent on the average drive time of trips. So … every once in a while I leave them on the battery tender for "top off". I also don't let them sit and run down and freeze anymore, learnt that lesson. Neither my 2003 or my 2014 is super fussy about voltage with all the modern features so I dont have any real symptoms of problems like it sounds like the newer Expys might.
One thing I think I picked up on is how resting voltage seems to drop over time. A new battery can be 12.35 but it drops as it ages and battery degrades and when it gets below 12 the battery is on its final days. I think. Which for me seems to be 5 years.
I like to know what to expect from my voltage reading … resting, fully charged, 24 hours later, while starting, running, running with lights on, etc … so I can take the pulse of the system at any point and know if I'm about to be in an oh shit position and track the health of the battery and charging system. I prefer to understand normal operation rather than wait until I have a problem and then try to figure out what's normal.
Artie
Georgia
We are debating on taking the Navi to Utah and doing the White Rim Road around Canyonlands... after we put some appropriate wheel and tires on it.
This 1000 mile round trip I just took to Ohio and back should have topped it off, if that didn’t do it nothing will.
Fozzy
Riverton
That’s, very interesting. Are you still having ASS and light, controls issues? If not, maybe the 12.3-12.2 is all we can push into the stock battery with the stock system. Last week it took my Optima charger (I have the big one) 8 hours to go from 30% to 100%. I didn’t even think to check the voltage. All my door lock and light problems go away after a good charge. I have only charged it twice in a year.
Fozzy
Riverton
This thread is about the ASS sucking balls. And I think this is one of the biggest problems. You save some gas but can’t recharge the battery. You go to the gym,work, take the kids to school and hit 4 stop lights truck shuts down with all the accessories running. At night you ad lights. It doesn’t run on nuclear energy. Putting a AGM in was a smart idea because they can take a beating and come back relatively unharmed. The ASS will not engage if the battery voltage is to low. In my experience the battery get to low and I get electrical gremlins. Door locks not working, lights flashing for no reason. ASS not working or telling me low battery condition. Full charge and everything goes back to normal. I have only had to fully recharge twice in a year. I also see thread after thread of people buying high dollar batteries and complain when they are dead in 6 months to a year. These batteries come with warnings about low voltage conditions. They need to be taken care of. Odyssey is my current favorite and they have service warnings for some motorcycle and watercraft that can’t charge them. Full charge is 12.84. And they claim a 10 year service life on a well maintained battery. This is old technology. Lithium Will be the future, but they are in the thousands of dollars right now. They claim 3000-5000 full charge and discharge cycles while maintaining 80% of battery output power until full discharge. Pretty amazing.
Artie
Georgia
I always turn the ASS off and I use the small version of that Optima charger. The only reason I checked the voltage is because I had ran a plug for my trailer and I was checking polarity and that’s when I noticed it was 12.2. This was the day after a 500 mile drive.
No members online now.
Landsbutter
