I'm towing with the max platinum. The problem I have is I'm 6'10 so I need something with a tall ceiling. This particular trailer has an interior height of 6"11. So I'm kind of restrictive of what I can get. The max tow with the expedition with a WDH is 9k. So if I carefully load this and stay below 9k will I be ok?
this rig is pushing it. a very experienced tow driver could probably do it with minimal risk.
Personal opinion here. Don’t tow anything over 27ft with a half ton truck. Or 30ft with a 3/4. Duley is needed anything over 30 for proper stability. You May say I’ll be save and keep it slow. But we all know people don’t. Lol.
That’s way overkill. We tow a 34’ airstream with our Max Platinum. Airstream is different though due to the aerodynamics.
To OP, you’d have to be careful on the prairies in a strong side wind but otherwise would be safe if your hitch setup is correct. Power would not be an issue with your Expy.
Obviously the solution is not just a powerful vehicle, I stated you’ll need the right hitch setup to tow confidently for a trailer that size. But power is the main factor in ensuring you’ll be able to accelerate while climbing a mountain, as an example.No, it is not "way overkill". the proper answer to this starts with a lawyer from the insurance company.
If you think the problem is limited to "power" then you do not know what you are talking about. Sorry to be harsh, but your attitude is dangerous and can get people killed.
