Forscan global windows
DWs-TTEB
Evans, GA
I understand that there are big differences between model years with what’s available in ForScan. I have a MY19 & I have the 3 year ForScan license. So, I’d attempt to buy the 1 year license at least for $10 & than look for the module. Also, just go explore the different modules you have to see if maybe global windows is somewhere else for MY21.
Rob6805
On my 21 the global window (open/close) function works through the remotes without making any Forscan changes.
wercsje1
wercsje1
Salem, OR
I don't know what submodel you have. I know on the XLT I went under my main dash configurations went to settings and then the vehicle and there was no window function in there to select boxes on until I went into Forscan. I followed some of the updates that were out there but no such luck nothing budged. And we've had this function on numerous other vehicles so I'm familiar with how it should be working. I did go in and enable everything to do with global windows as well as the rear global windows but still nothing I'm sure it's just one code I'm missing
wakeboarder
Fort Lauderdale, FL
I don’t think rear global windows will work because it does not have the correct module for one touch up and down.
This thread has some more information, but it may be different for the 2020’s and 2021’s.
Super Moderator
Super Moderator
Like @Rob6805 said, did you check to see if it already works?
Also, you have an XLT, do you have the one touch up/down on the 2 front windows? If you don't it won't work.
Also the 2020/2021's have a few module differences than the 18/19's and sometimes things do not work. DO NOT use the hex coding that worked on the 18/19's on a 2020+ because you will not be changing what you think you are.
Also, don't need to pay for a license, just need to request a trial license. It is fully functional. Of course, I HIGHLY recommend paying too, because supporting the FORSCAN geeks is highly recommended.
wercsje1
wercsje1
Salem, OR
I do have one up one down and I can code it to put the window prompt under vehicle settings on dash. It just will not work and nobody has any info on a 2020 or 2021 as far as adding it. I have checked 3 different Ford sites and no luck.
Super Moderator
Super Moderator
Because of the changes to the modules for 2020+. Nobody has mapped it out. It is not like there is a magic decoder ring for this stuff. Coding changes are found by either trial and error, or comparing coding from versions of the same modules with the feature turned on.
On most Ford vehicles 4 modules need to be edited to add Global Open/Close.
Those modules are:
BCM(Body Control Module)
DDM(Driver Door Module)
PDM(Passenger Door Module)
APIM(What controls Sync) - Technically not a requirement, because it just turns it on and off
Since it is turned on in our Limited from the factory, I have never dug in to see what is there for drop down options. You could possibly try 2020 F150 coding. It is the closest coding to the 20/21 Expeditions.
