Let's See Those Lifted / Big Tire Gen 4s!!
Lou Hamilton
Trying to decide between 295/70/18 and 35/12.5/18 on my Timberline. Front end is definitely lifted compared to other 22's I compared on the dealer lot. I've been really busy but going to mount my 35/12.50/17's from my Raptor as a test fit. Definitely need more tire width for FL sand. Looking at suspension options.
I think that I am going to go with 285/75 R18's on my Timberline. They are slightly bigger than the 285/70 R18's that I have on my 2019 one.
Just need money now after dropping such a big chunk of change. LOL!
LazSlate
Arizona
The tire sizing is so close. The 295/70/18 is 34.3 wide and 11.6 tall and the 285/75 is taller at 34.8 but narrower at 11.2
Would love to see a 3 Timberlines with 285/70, 285/75 and 295/70 to see which is too much in height and which is too much in width. The 295 is 1.2" inches wider than stock, wonder if it fits in the wheel well with stock rims or is a 285 with 11.2 width the way to go 3/4" bigger than stock.
Lou Hamilton
I'll be going with wheels with a different factory offset.
I will be sticking with my Black Rhinos with a 12mm offset. Factory is 44mm. I am esentially pushing the wheels outward by 32mm with the wheels alone. My 2019 had 285 width tires and that seemed like a sweet spot for not having to cut or trim anything.
Lou Hamilton
The Timberline comes leveled from the factory. I just checked and am at 37 3/8 inches at both the front and rear wheel wells. The ReadyLIFT might give me a Carolina Squat and I really don't want that. LOL
Expy Gator
So I mounted one of my 35x12.5x17 Nitto Ridge Grapplers on the Timberline. I think the wheels are 17x8.5 34mm . Actually was surprised there was as much clearance. If I was going to run that combo I would pull back the fender liners. I think I just decided I'm going to run a 295 rather than the 35's.
Lou Hamilton
Thanks for the update. I can't wait to get my old wheels and try them on. Granted, I only have 3 good ones. I will need to buy a 4th wheel and tire.
Lou Hamilton
Here's a few more:
Thanks.
My current inexpesive thought is to just go the 2 or 3 inch spacer route for now (suspension spacer not wheel spacer). Since it is already leveled, the 3/2 ReadyLift won't work right.
I'l have to buy 1 wheel and probably two tires (at a minimum) in order to get the old wheels road worthy.
Then, I will have it back to the way it sort of was with my 2019.
Expy Gator
Thanks.
May be interested in a 1 1/2 or 2" spacer lift F&R. Let me know what you find!
Coop7379
Jacksonville fl
Rough Country 3inch Kit
295/70/r18 (34.5”) Cooper Discoverer AT3 XLT
Pro Comp 40 Series Vertigo Wheels
Relocated Fender Liner
16.5 inches of clearance at running boards behind front tires. 17.5 inches of clearance at running boards I front of rear wheels.
No rub whatsoever with this setup!
this set up looks great, I am waiting for my rough country kit to arrive in the mail. now I know what tire size, the question will be am I going to need to put wheel spacers on it because I plan to run the factory fx4 tires.
Lou Hamilton
Can you share what Rough Country lift kit that you used?
Was it a straight bolt on for the rear? The company I am talking to said that is their only concern.
Thanks!
sjwhiteley
Kentucky
That’s the kit which moves the rear wheel rear wards to center it back into the arch, correct?
Expy Gator
We will see on Tuesday - I have Nitto Recon Grapplers 295/70/18 being mounted on stock rims
Lou Hamilton
Mounted 295/70/18 Recon Grapplers - no clearance issues. Big improvement from OEM. I was prepared to modify fender liners but will wait to see what I need after flexing.
Any side profiles? Did it add any poke?
I'm getting ready to install my old 285/70 R18's with the Black Rhino wheels later today. I am just waiting for the new lug nuts to arrive. The stock ones are too wide at the base and would not fit on the Black Rhino wheels.
I do like the stock wheels. So, my other option is to swap the tires off the Black Rhino's and on the stock wheels. Since the Black Rhinos are already setup, I want to try them first. There is a HUGE offset difference between the two -- 44mm OEM versus 12mm BR.
Expy Gator
Really no poke at all but they are a +44 - I’m prob going to space them out a little.
Lou Hamilton
Added my 285/70 R18 Nitto Ridge Grapplers on the Black Rhino Chambers (12mm offset).
I did some intentional super sharp turns forward and back as if I was pulling my camper into a campsite. No rubbing. No trimming either.
I am still going to add a 2" puck lift for it and then replace the tires with 285/75 R18's when my current ones need replaced. This will take me from a 34" x 11.5" to a 35" X 11.5" tire.
Unfortunately, I forgot to take before shots to compare. Sorry.
LazSlate
Arizona
I have always been a BfGoodrich K02 buyer. They do not see this size. What made you pick the Recon?
Do you know which is like the BFGoodrich?
I see they have Ridge, Terra G2, Recon, Terra AT
