11. Now insert the pads into the mounting positions. I did the inside pad before the outside pad because it was easier to hold in place while mounting the front pad. Once the pads were on, I re-installed the (piston-compressed) caliper. Also, take note that the arrow on the pad with the word "UP". Apparently the pads are directional, but you wouldn't know it by looking at the friction material.
I was able to hold the caliper bolts with my fingers until they tightened up enough to crank down with the ratchet.
Finally, I reinstalled the wheel, torqued the lug nuts to 150 pounds (!!), and then reversed the procedure above to exit out of parking brake maintenance mode.
This side of the truck took me less than 45 minutes - the other side was a little over 90 minutes because I could not for the life of me get the rotor off using my small sledge - I had to upsize to the big guy.
Hopefully this helps someone. I saw a comment in another thread that this was easier than changing the oil. I could not possibly agree more!
Fronts coming soon....
