2004 Expedition no 3rd or OD
tsamrein
Sullivan
I just acquired an expedition with this problem. It works perfectly in 1st and 2nd but doesn’t shift to 3rd. If I unplug all the sensors it locks in Third and can be driven at highway speeds.
Anyone have any ideas what would cause this.
Run a codes check first. 2 things come to mind. 1, the passages for the 3-4 shift are gummed up in your valve body, and 2, you might have a bad shift solenoid. The second should show on the diagnostic with a quality scanner. The first you'll have to drop pan. If fluid is gritty, or dirty, and did cause the valve to stick, you might have a torque converter going bad. Check fluid color, and condition first. Get a clean white paper towel or blank computer paper. Wipe a sample on it, see what it looks like. Have you been regular with your services at 30k? Real important with the heavy loads. I believe you have the 4r80 trans, correct?
TobyU
Ohio
Sounds like a shift solenoid to me. Get it scanned.
T
tsamrein
Sullivan
I will have it scanned as soon as a light is present.
I have a little more information after finally getting to drive it again. If I leave it in drive it doesn't want to shift to 2nd from first. But if I put it in 2nd it will shift from 1st to second.
Also the speedometer is not reading. At 35-40 it registers about 15
Sent from my BLN-L24 using Tapatalk
TobyU
Ohio
It could even be a MLPS Manual lever position sensor (neutral safety switch on side of trans) or a VSS vehicle speed sensor- usually on trans some have two or an output shaft on too.
Both could mess up shifts.
T
tsamrein
Sullivan
Sorry for the delay in getting back on this.
I replaced the VSS and it didn't change anything.
So to recap the transmission drives in 1st gear if I put it in drive, it doesn't shift up any gears. If I put it in 2nd gear manually it shifts fine from first to second. Does not shift to 3rd or 4th.
Sent from my SM-G950U using Tapatalk
Your now throwing parts at it. You don't need a check engine light to have a stored code. I'd sure hate to see you buy $500.00 in parts, and still be broken. Seen it here way too much.
TobyU
Ohio
I thought those stayed in 2nd if you put them in it.
All my fords start in 2nd and stay there if you out them in 2.
T
tsamrein
Sullivan
Yes it does stay In second if put in second. I was meaning if I manually shift from drive or 1st to second.
T
tsamrein
Sullivan
I hooked the scanner to it but there are no stored codes or pending codes. I drove it around for a while and still no codes.
Now the plot thickens! How good are you at transmissions?
T
tsamrein
Sullivan
I have rebuilt a few. Albeit mostly chevy's, but automatics are mostly the same.
I feel like this is another issue. I know these transmissions are notorious for the direct drive clutch breaking but again not convinced that is it either.
T
tsamrein
Sullivan
Bit of an update. I still don't have any codes. I did check voltage at the OSS and I am only getting. .2 volts at the sensor and at the computer connector.
Any ideas?
T
tsamrein
Sullivan
Justin figured out someone put a 2003 transmission in my 2004. Is there any way to make them work together?
Sent from my SM-G955U using Tapatalk
Might have to change computer and reflash. Wow, 1 year and doesn't work. Did you just buy vehicle?
T
tsamrein
Sullivan
Yes. Just bought it and I knew of the problems but never would have thought I would have to make a decision whether or not to pull a rebuilt trans because of a 1 year difference
Temple, Georgia
The transmission rebuild kits are different so there are internal differences. Anything is possible but it would be an uphill battle.
Might be easier to swap in a cluster and pcm from a 2003 depending on any engine differences.
T
tsamrein
Sullivan
Good enough. Guess it is finally time to buy that transmission Jacko always talk about. Lol.
T
tsamrein
Sullivan
Stamp. That was what I was wondering. Why the cluster? Just curious.the pats is stored in the pcm in 2003 also I believe.
Temple, Georgia
Cluster and pcm are married together electronically.
This is Ford now, won't be plug and play. You would need to compare wiring pinouts to the pcm and cluster for the two years. I would also expect to move a few wires around.
Also look at the sjb wiring for any circuits tied to them.
