Air Intake, hmm....
Explor2Exped
Nashville, TN
panda24619
San Diego
$48. you might as well get it, but wrap the shiney in some sort of heat reduser. someone will know more of what i mean. it will give you more hp and trq since its less heat.
Explor2Exped
Explor2Exped
Nashville, TN
"The insulation can be picked up at most auto parts stores, I got it at my local Oreilly's for fairly cheap. It has a "sticky" backing so all you have to do is pull off the backing paper and wrap! Make sure you have a good pair of scissors or an exacto knife handly for any cut outs that you will need to make to get around sensors. Also make sure to get the "thick" insulation that has fiberglass in it, they have some other stuff that is like reflective paper but that won't do any good."
-Racenut
Explor2Exped
Explor2Exped
Nashville, TN
but this is definitely better than the stock air intake?
panda24619
San Diego
o yeah! i wont get it since its not on my list of stuff to get, but it will help. if i were you i would change that filter to a k&n asap. but thats just me.
KWT2000
NINE MILE FALLS
their is a couple options.... if you want the shiney look you can have the in side of the pipe ceramic coated, or wrap it in header wrap which will take away from the astetics..
you should be able to install that in about 30 minutes with basic hand tools and a set of torx bits...should be all you need
jacks3am
michigan
yeah that looks like the one racenut has, just wrap it and you got an intake as good as a k&n basicaly
walnuts4x4
Watertown, NY
any CIA is easy to install... just uses hand tools... but before you buy a ebay cheap-o... look into the "gotts mod"... I would have done it but already dumped the cash into a K&N FIPK.... but my old 97 F150 had a similar ebay intake and it is still on the truck... just saw the truck the other day.... needs a new motor now...
Explor2Exped
Explor2Exped
Nashville, TN
What's gotts mod? This might have flew right over my head, hah...
walnuts4x4
Watertown, NY
picture.php
yes they do look nice though
FtLaudBlkGT
Even with one of those CAI kits, you are still sucking in hot air from the engine compartment. With the GOTTS mod, you are pulling cooler air from outside the engine bay.
walnuts4x4
Watertown, NY
mine was free.... so I put it on... and I didn't know about Gotts mod when I got expy... so I left mine on... looks better at shows
Racenut
Deming, New Mexico
I just wish that I would have found the "gotts mod" before I threw out the stock air intake! I would change it in a heart beat because the heat soak sucks in the summer. As it is I am trying to find a way to route some stainless into the fender or down low so I can get some cooler air than what I am getting now.
Big Red Monster
I think if you were to do the "gotts" mod and use the kit True flow sells you would probably make the most horsepower seeing as the true flow pipe is like 4 inches open and the gotts mod helps deliver the most cold air possible from the fender. having an exposed filter gets alot more air in to the engine but that air is also hot.
Scottandtyson210
Puyallup, WA
Just did the GOTTs today, make sure you have a sander or dremel ready for the reshaping of the pipe to make it oblong, that was the most time consuming but that was maybe 30 minutes. Now i just need to get my K&N filter to drop in and really reap the benefits....this was the way to go for sure, parts cost $10
Big Red Monster
an easier way that u dont need to reshape or file anything when doing the Gotts mod is if you use a piece of exhaust tubing, saved me like 1 hours worth of extra work and fits perfect in the fender well
