AWD Mode
Dan Faoro
Fairfax, Virginia
We have a 2020 XLT Max and I’m uncertain over which drive modes to use. We are about to do a long road trip that will take us through the PA mountains to Chicago. I’m anticipating at least some patchy snow and ice. What is the best mode for highelway speeds in these conditions?
Normally on a rod trip I put it in ECO mode and set the cruise control. Is running it in ECO with 4A on a good option for a trip like this?
D
Dan Faoro
Fairfax, Virginia
Yes, that’s my thought. 2H when it’s dry or just wet, but 4A if there is any snow showing up, even if patchy which is where I am most concerned.
Gumby
Beaumont, Alberta
If you run 4A on bare road the front axle is spinning and sucking fuel. Run it in 2H when the roads clear, then use 4A when the snow shows up if it ever does.
Literally this. I just did a 10-hour drive through sketchy and hairy weather in the mountain passes through Alberta and BC. I varied the awd from 2H to 4A and never touched the drive modes. In fact, I rarely use those modes at all...and I have gone through some seriously gong show weather. The Expy was just fine. I also run studded Nokians so that plays a role for sure.
lv2drive
PA, USA
in my experience, i have seen zero difference in fuel consumption after extensive highly varied driving in normal mode 2H or normal mode 4A, for comparison purposes.
if there is a mpg difference, it's not showing up with any significance on my repeated actual per-gallon maths 90% of the time from the exact same station / same pump / same octane, for the entire pandemic basically....
(not sure if it makes any difference that i've got the 4wd / 3.31)
i did not really believe it at first, until i methodically tried it for both long trips & local city driving as well, just to make sure i was actually getting the same results in either mode & in all conditions. i know the front axle is spinning in 4a of course, so there is obviously the potential for extra wear, but i have a warranty for another 8 years & 100k more miles, so i don't really care about that so much - so far i've got about 10k running in 4A daily & no issues on the front end have appeared yet, currently @ 50k.
who knows maybe i'll eat my words in short order, call me crazy but i *always* run mine in 4A because the front end steering tightens up significantly & i prefer the way the truck handles on our back country roads - plus i usually have to to actively evade to avoid a deer at least once a week, sometimes in pretty extreme cornering & ending up damned near sideways, so i would rather have the truck in 4A in general just in case i started to lose any traction for any reason, wet, dry, wildlife, whatever...
i'm sure i'll get flak for it - but in short i've not been able to show any MPG difference between them & i love leaving it on 4A - all. the. time. (until something breaks & i come back here complaining about being stuck in an escape while they source parts...)
Kudie
Ohio
Front hubs are always locked on the newer f150 and expedition
Everything is always spinning.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
That is a 100% inaccurate statement. Do a search on a 150 site for IWE, or in the case of the 2021+ EIWE, and do some reading. They definitely lock and unlock depending on Mode or Drive selection. In 4A on the 150 and Expedition, they are engaged, but the Center Diff only sends Torque forward when slip is sensed.
Soliyou
OK
Yeah, they finally ditched the vacuum operated hubs and started using an electric actuator.
I am interested in the idea of retrofitting these electric hubs in place of the current air hubs. If they fit mechanically, we can run a control wire from the vacuum solenoid and power them directly from the battery.
sjwhiteley
Kentucky
Depending on your tires: I have the OEM Hankooks which are marginal, so use 4A in wet conditions. The rear tires have slipped. The 4A helps keep things aligned. Better tires wouldnt have this problem.
