Killer Ride
You can have an exhaust guy do a back pressure test they usually do it for free
Sent from my SM-G950U using Tapatalk
I don't use Motorcraft products at all tbh with you, I feel as if their products are of cheap quality. & I use the Purolator boss or Purolator one can't remember which one exactly off hand. But they are rated for 10,000 miles. And even though the max life synthetic blend is rated for 5000 miles I never go over 3,500
Sent from my SM-G965U using Tapatalk
I heard Rotella sometimes works, I guess I would need the high temp for when Vegas hits 120°. And it isn't dripping at least. I wouldnt hear the end of it if the truck started leaking in the driveway. Lol.
I used to manager a Valvoline, and I SWEAR by their products. I use nothing but Valvoline Max life synthetic blend high mileage and Purolator oil filters. Needless to say my expys have served me well
Last I heard, the Motorcraft was a made by purolator and a pure one media in a standard white can.
I am not a fan of overpaying for OEM just because it makes many people feel better but you need no better than a Motorcraft filter. They are also super cheap at Walmart.
ExactlyIf you buy a new vehicle and only use OEM Parts you're just trying to make the manufacturer rich a second time or at least you continue to line their pockets with money.
Plenty of Parts out there just as good as OEM and some over the years have been a good deal better, but all at a significantly cheaper price than going OEM. Especially when you consider that in years past your only option was to buy from a dealer. At least now there is a little bit of competition online for OEM replacement parts.
If you want to use OEM parts that's of course your option but admit you do it because it makes you feel better. No one has a better vehicle because they put a Motorcraft ball joint or control arm or pads and rotors on their car over other brands available.
Maybe don't use Rotella since it is formulated for diesel engines. Find the source of the problem and correct it verses jackleg "fixes".
You may want to perform a leak down test on each cylinder to check the rings.
I just drove up and back 1100 mi each way and on first leg driving @ 75mph w jaunts up to 80-85mph I burned 1 full quart.
On return I planned to baby the ole gal but due to lighter traffic and everyone else hauling ass I set cruise control at 80mph w longer intervals at 85 up to 90 on down hill stretches of I24 in Tennessee. Consumed 1 1/2 quarts w hotter weather.
I just changed the oil today. I arrived last night. Drove through 18 hours stopping for gas and coffee.
I use Kendall GT-1 5-30 synthetic w liquid Titanium. Made by ConocoPhillips the same company that makes MC oil for Ford. I use MC oil filters only.
She’s a man baby.
I wish I could find good aftermarket suspension parts that aren't OEM. Used to buy Moog, but they've gone Chinese and the last two parts from them were junk.
Otherwise, the chain parts stores carry Auto-Max, Car-Quest, Driveworks.... all import garbage that will hardly give 10K miles. Or I can go on-line and get Mega-Dragon.
Help!
I read Ford engineers, expect an engine to last 300K Miles with scheduled maintenance. You sir, are well beyond that. You can try pulling out the dipstick about an inch. In the late 90's, I had a winter beater, Hyundai Excel. It burned oil like crazy. The valve seals and rings were shot. I was told, as you take your foot off the gas, it creates vacuum. The vacuum would suck oil past the worn engine parts. Pulling the dipstick creates a slight vacuum leak, to prevent this. I tried it and cut oil burning in half. I gave the car away in the spring and the girl blew the engine 600mi later. She never check the oil and threw a rod.
