Hope u drive with it unlockfirearm of course.
Sent from my SM-G981U using Tapatalk
I too tried one!
Just finished installing the E&G Classis console vault. I have to be honest, the craftsmanship and fit was perfect. Install took about 40 minutes but I also took it slow so as not to screw anything up. Very simple.
Couple install notes:
1) Be careful with the plate that slides under the console (you can see the black plate in the picture with the trim removed), it uses cages nuts (for anyone familiar with those) and they can pop off. Luckily mine didn't but they can. Make sure you slide the plate in on the left side and truly, don't pry up the console too much, I only had to pry it up about 1/4" or so to get the plate to slide in perfectly.
2) I also cut one of the corners off of the factory tray so that I can get a USB cable to still exit the console in the appropriate spot. The design of the vault doesn't have a spot for the cable to come through. Super simple, just cut the corner of with some dikes.
3) I disconnected all accessory cables that I could reach before removing the bezel, when those plastic clips pop, sometimes they come off hard, and I didn't want to risk pulling or breaking a connector.
Very impressed with this, well worth the money, I found a great deal on one at CarID, they were on sale for around 265. https://www.carid.com/eg-classics/console-lock-vault-mpn-7045-1000-17.html
Florida has rules???I get it, just that as I had understood it, it has to be in your possession at all times or at home... maybe I misread.. Florida rules are weird...
