BakerEdition
EF Chaplain
I had a problem that had me on a goose chase...from time to time I was told by other drivers that I had a left stop light out....I would get home check it out and it would work...so after checking all the obvious...I was sitting in the truck after backing it into the garage, had my foot on the brake and the light was out...as soon as I tilted the steering wheel up, the light went on...shit...then I tilted the wheel down and out it went....ahh..ha...so I checked the connections on the bottom of the column and all looked good...so I opened up the plastic around the column and saw the two wires that are in the picture below that were half way out of the plug...So, I took out the two screws to remove the multi-function switch(turn signal lever) and unplugged the two plugs and repaired the loose wires...I put a cable tie around the wires coming up through the column to stop them from moving when tilting the wheel. put it all back together and problem solved....no money spent, just some time.
