We’ve been having some cooler weather here in NY, fall is on the way. Kind of a nice transition from the heat.
so you have a full aftermarket brake kit on it, including 4 piston calipers, and newly sized discs?
so your truck, stock, came with 14.2" rotors and 2 piston calipers. 12k lbs, double the weight of our rigs with .4" more rotor and can tow another 12k lbs, but you think MAJOR changes should be made for safety. GTFOH. it is ok to admit you were wrong, we wont think less of you.
i want to make sure to clarify my position here, the stock brakes on this truck are MORE THAN ADEQUATE for the vehicles intended specs, design, and usage. I would go further to say they excel at their ability to stop this vehicle. I have worked them harder than most and have experienced no fade or shimmy. 70mph down a 12% grade having to slow for a 100-110 degree turn. It has been the torture test for all of vehicles. the expedition is the only to pass it stock. every other vehicle we have had needed to be upgraded to power stop rotors and pads to not fade and vibrate.
Correct it's a completely aftermarket setup.
My main point is I don't like having to mash the brakes for a full stop. Especially for a female driver like many of our spouses if in an emergency situation there's a ton of slack.in the pedal. I mean where's the damn emergency brake in these things anyways lol?!
i here you, we can agree to disagree here. you have some sick rides. not a dodge man, but i respect the cummins!!!
Guy read the context, the other poster was talking about bimmer brakes, and I just so happen to have one of those lying around to supply a point of reference. Now you're bringing a 16.5" rotor in the equation that uses 8 pistons per caliper lol. Really?
The expedition relies on a 13" with 2 pistons yet this would be the perfect setup for your odd choice of reference.
Clearly this setup is overkill, but even a 3 piston design would make big difference in ability to stop.
