chuck s
- Joined
- Dec 20, 2006
- Posts
- 1,823
- Reaction score
- 672
AOS? (Google came up with accessory olfactory system but that doesn't seem to fit).
-- Chuck
-- Chuck
As a kid, I used to believe that thicker was better protection. In fact, thicker can mean higher pressure, but can also mean less volume. Anyone that has worked with oil pipelines can confirm. Thicker oil increases line pressure, but barrels per hour is reduced. Some engine components need to be flooded with oil rather than depend on high pressure. I switched my 2011 to Edge 10W-40 when I purchased it used. The vehicle tossed a roller rocker about a year after purchase. I replaced only the single burnt rocker and switched back to recommended weight oil (still Castrol Edge). I have since put 60,000 additional miles on the vehicle without another failure. I do change oil quite religiously. Just my personal experience. Take it for what it's worth.I do not. My personal choice has been Castrol Edge Full Synthetic 5W-30. However, I have read a surprising number of posts where people are using a different weight oil then recommended by manufacturer. That was reason for my question.
I do not idle much. We are going to go from Northern Michigan to Tennessee this week. I will check at 250miles and adjust when I check from there. I will bring a glass jar with me so I can empty it and take pictures. Thank you all for your advice and I hope to get back to the is next week when I return.Perfect. You are welcome to post a picture, but it is due to the cold. Do you idle a fair amount? That will typically cause it to collect more moisture.
You do not want to dump the crap caught in an oil catch can back into the oil pan. That doesn’t make sense.The AOS does the same thing as the catch can, but also drains back to the oil pan. No dumping necessary.
I looked at the Team RXP catch can and believe you when you say you have had good luck with that brand. However, it is like 4 or 5 times the price of JLT catch can. My experience with the JLT catch can has been very good. I currently live in Georgia and certainly don't have the cold conditions of the OP so my experience is different. Might be worth the extra money in cold winter states but the JLT has worked perfectly for me. Even after my 5,000 mile trip this last Aug my can was only about 1/3 full. Certainly no accumulation like that expressed by the OP @RockyRobI’ve been preaching about the Team RXP catch can forever on this forum about how it only collects oil/gasoline and let’s the water vapor through to the combustion cambers. It’s not a bad thing either to introduce water vapor into the air fuel mixture either. It actually helps with fuel atomization for a better burn. Mine has never collected a drop of water so I can wait easily to dump it every oil change. No I have no stock or connection with that company. I’m just stating my experiences with this catch can.
