Thanks for the write up. I've made this a sticky, since it seems to be a common enough problem.
Well, just finished taking about my rear quarter panel, still putting it back together.
Basically, the motor that controls the door that decides which way the air goes (roof or floor) is bad. Well, not the motor, but one of the gears. It's the same exact motor that is used for the temperature blend door, so I'm not surprised that fails, as well.
So, as a temp fix, I "set" it to where the door would remain for roof air only, and disconnected it. I'll be looking for a replacement one at a junkyard or something. You can get one new from rockauto.com for 39, though WhiteFX4 said he got his from the dealer for 35.
I'll post instructions on how to take off the rear quarter panel later, as well as some (crappy) pix. I'm also going to try and see if the motor is accessible by taking out the cup holder. Would probably save a lot of time doing it that way.
