Yes, there are several ways to determine the MAC. You could connect you car to a Hotspot or to your WiFi broadcasting for a short time, to determine the MAC.
As far as not broadcasting your SSID, and MAC filtering your network, both are easily bypassed if somebody wants to. A Good WPA2 passkey, or WPA2 Enterprise setup are far more superior at securing a network, than the other 2 methods. MAC filtering can be used as part of an Enterprise solution to be the gatekeeper, but it is easily defeated, if any of those allowed devices are allowed to search for previously unknown networks, because then the MAC of an allowed device can be gleaned and spoofed.
As far as connecting to a Non-broadcasting network...I will give it a try later, and see if there is a way. Honestly never tried.
Remember the WiFi radio in the Sync Module is only a 2.4. It won't even see a 5Ghz network.
The WiFi radio antenna for connecting to a WiFi network is internal. It is meant to intentionally not have much range. It is meant to work right next to your house or in a garage.
If you are attempting to use it to do updates, I HIGHLY recommend you download and install via USB. Best way to do that is via CyanLabs.net.
Appreciate the response, I design wireless networks for customers so I fully subscribe to defense in depth, using layered approaches is always best, and yes, I do use additional mechanisms, like WPA2, and even for certain networks, MFA.
Regardless, I went through all of the menus and literally don't see a way to manually enter network information. No worries on not having 5Ghz support, I'm leveraging both. I've tried both methods for doing updates and neither is very reliable, I personally think the update process needs some serious help. Leave a car running for over an hour to do an update? Sweet, just negated fuel savings/reduction in emissions of auto stop/start for 2 weeks. There's needs to be a much better way, I hope ford in the future supports something like staging the update from USB to internal memory, with background updates, or something like a hibernate power mode, where full accessory power isn't needed. That is, all of these systems are integrated anyway, the head unit should allow me to select a "update during hibernation" setting, that tells the power management subsystem to leave the head unit/sync3 system on during the entire update cycle, but leave all other accessories off, to save power it could even turn the display off with only a periodic message of status.
Ford is becoming more and more of tech company, but you can tell they're only partially there.
As for the MAC, I suppose I'll use my phone and see if tethering it will help me get the MAC, but it does me no good if I can't manually add an SSID.
My 2018 let’s me connect to my 5G..
Side question though. My Sync 3.0 wouldn’t find any updates. I downloaded the 3.3 from Ford and successfully installed via USB. I cycled the key a few times, 5-30 min each time, yet my Sync still shows version 3.0. Any ideas?
Is it letting you connect to a Network that is only 5Ghz? Or a network that is both. Looks like I need to go look again. Maybe the 18+’s actually do support 5, and I made an assumption. The 16/17’s only supported 2.4 verified that many times.
If you successfully installed, then your version would change. Are you sure you got a 3.3 install, and not a newer revision of 3.0?
Post version info for me? Also the file info for the file in the root of the USB drive. A screenshot is good for the drive root.
Sent from my iPad using Tapatalk Pro
