Why does Ford still use such wimpy brakes?
Haven’t most manufacturers moved to 4 pistons on the front with bigger pads for 1/2 tons in the last 2 decades? My passenger side front seized up so this morning I hunted down one I could find in stock today at NAPA....no dealers locally had stock. Doesn’t seem like much brake for the weight they have to stop. Seems to be well built and good corrosion protection but it seems the OE overall design could have been heavier duty.
Trainmaster
Old School Member
Rockaway Beach, NY
I don't like the brakes on the 3d Gen trucks at all. Was so concerned with them that I replaced everything with new Motorcraft stuff. Better, but still a bit concerning. Hard to believe they use these in police work. Feels like my 2000 had much better brakes with shorter stopping distances.
Plati
I wonder what the benefit of 2 pistons would be, from an Engineering basis? The hydraulic pressure from the brake line doesn't change so that pressure would simply be split between 2 calipers vs one … resulting in the exact same force on the brake pad? New caliper has double the number of pistons so doubled probability of failure. No longer centered piston so if one is weaker you have unbalanced pad pressure, would not be best. What is the benefit? Do you still use the same pads?
not a slam, a fair question, kind of Negative Nancy I guess but interested
Flexpedition
midwest
If 60-to-0 braking feet distance is a measurement of Expedition braking ability, the below are results from various magazine testing:
2000 = 139'
2003 = 140'
2007 = 135'
2015 = 147'
2018 = 129'
You'll find plenty of slight variances on the web, plus or minus 1-2 feet.
By ways of comparison, 2017 consumer reports mass produced vehicle best and worst:
Corvette Stingray 3LT = 107'
Porsche 911 Carrera S 108'
Toyota Tundra SR5 = 153'
Jeep Wrangler Sahara = 157'
If you find the Expedition brakes inadequate, and if you've also recently rear-ended somebody, you might want to rethink following distances. :)
cmiles97
Tampa, FL
I have to say the 19 Expedition I rented did have a much tighter brake feel than my 17. I didn't pull a wheel off to see what they have for brakes.
My 17 is fine, I never feel unsafe while stopping even pulling a 6,000 lb trailer. I adjust my stopping distances for what I am driving. Heck I really don't know what kind of brakes the 17 has either. LOL
This is an OE style from NAPA, the stock calipers on my ‘07 are 2 piston same style as pictured on the new unit.
HawkX66
Semper Fi!
VA/MA
I'm surprised to hear someone say the Ford brakes are wimpy. I don't think anyone has gone to four piston calipers on regular builds, but I could be wrong. That's more of a performance thing. If you've ever had to panic stop with a 3rd gen Expy towing a 10k lb trailer, as long as the brakes are in proper working order, I don't think you'd say they're wimpy. I've found them to be plenty beefy.
Toyota uses a 4 piston setup on many from what I’ve read in the past. Here is a set of Tundra calipers. They look a lot more up to the task than ours:
2000 = 139'
2003 = 140'
2007 = 135'
2015 = 147'
2018 = 129'
I was a few car lengths back, that doesn’t do much on a state road going 55 MPH when a drunk driver slams on the brakes and decelerates to 0 on a dime. My truck went into a skid and had zero braking power so it’s not the brakes fault in that instance. No reason to be rude though.
It seems piston #s don’t matter, since the tundra scored terribly on the results you posted.
That is a good article, thanks for that. I never looked at it that way but mathematically makes proper sense. The smaller the pistons, the less surface area.
JasonH
Houston, TX
If you can lock the wheels on a dry surface, the brakes are not the limiting factor. I haven't tried it...maybe someone else can do so and report back.
Plati
Can't ever lock brakes with anti-lock brakes, unless the brakes are broken badly?
TobyU
Ohio
I can't stand 4 piston calipers. I even prefer one over two.
Keep it simple and cheap.
I don't know what a person is used to driving if they find any newer (or any typical operational brake system for that matter) not completely adequate.
I guess if you drive a Corvette or performance car and drive it hard...which is abnormal for normal cars on the street, then you might think a 6000lb truck didn't stop as well!!!
I have had no complaints at all about any factory vehicle I have ever driven. I have no need to hammer the brakes and if I need to stop abruptly, they do just fine.
Trainmaster
Old School Member
Rockaway Beach, NY
Hey Flex.... thank you for the comparison of stopping distances. My 2000 always felt more nimble than my '08. but your chart shows they are similar. I guess it's just the difference in pedal feeling... Nope, haven't rear-ended anyone yet. With a 5,000 pound truck I keep my distance.
Hehe I don’t recommend but if you get it up to 50 and put the brake pedal to the floor.....that ABS system squirms....she will skid. When you apply that kind of braking force at higher speeds ABS reaches its limits. Purely dangerous as traction is gone.
I take my part for the accident. I wasn’t as far back as I should have been at that hour of the night, the driver in front of me was clearly intoxicated (I should have kept away) moreso seeing that. I certainly learned to follow further back at all times from that fiasco.
TobyU
Ohio
I feel sorry for you for that one. The other guys drunk can you get the ticket for hitting him. Ironic but still very unfair.
Oh no I didn’t get anything, he got fines up the *****. He fled the scene and got hammered for wreckless driving and fleeing the scene of an accident, I got a friendly reminder to steer clear of dumb*sses is all.
TobyU
Ohio
That's excellent! And damn lucky too except the fact that your vehicle got dinged up.
