Those are the same wheels I have.
You have good taste!
Sent from my SGH-T999L using Tapatalk
Mind sharing what bearing part# / brand you used? I did this on my wife's car about six months ago. Saved a bundle. Thanks!
I don't EVER recommend to my customers to press the bearings out and reinstall on Ford pulleys!!!!!!!!!!
They are stamped steel and when you press the bearing out and the new one in, the press fit is gone. That means during regular driving, the pulley can and may walk itself off the bearing.
but this kind of backward thinking has got through life a lot if years.That's great info/perspective from a guy that sells bearings everyday...but as I've already laid down the cash, I'm going to have to have to roll the dice. I wonder if it makes sense to either score/marr the outer bearing or the inside of the pulley, slightly crease/dimple the pulley ID on either side of the bearing, or use adhesive of some kind as a preventative measure. I know...but this kind of backward thinking has got through life a lot if years.
Just read this... I may try it: "When you go to replace the bearing, freeze the bearing (overnight) and throw the pulley in the oven(hour at 450*). Then press it in."
