17LimitedExpy
I tried the turn signal lane change amount of flashes. Originally truck flashed 3 X's. I'm not sure the way the spread sheet reads to adjust this it shows what digit to change, but for say 7 flashes it shows E-F? So I tried just replacing the ? mark with a F. Well this did the lane change to 7 flashes, but when you used the turn signal and it click's back after the turn, the signal would continue to flash! At least until you would use the lane change. So I went back in and change the value from F to A. it now works as should and has 5 flashes for lane change. So I didn't under stand the way it shows two symbols in place of the ? mark. I just used one and was happy once it worked the 2nd time, so where did I go wrong?
Turn Signals - Lane Change Flashes SCCM 724-01-01 xxxx x?xx xx
I tried 724-01-01 xxxx xFxx xx
Then switched to 724-01-01 xxxx xAxx xx
The 2 different characters on the spreadsheet are because it depends on your vehicle which setting to use. Ford used several different module type so we can’t specifically say what character works for each Expy.
The ‘E-F’ you refer to is telling you to change to an ‘E’ or change to an ‘F’...since you tried the F and it stayed on, then your vehicle needs the setting of E.
Does this help answer your question?
